HI Dears If i want Assign Policy-map to VLAN by time for example 8 am to 8 Pm 2Gbps8:01 Pm to 7:59 AM 4Gbps How can do this by ASR routers ????
The content you are looking for has been archived. View related content below.
I’m just making sure on this. If you have two GRE tunnels whose source is the same interface, both MTU would still be 1476 correct?For instanceInterface gig 1/0/1ip addr 192.168.1.1 255.255.255.252tunnel 1ip mtu 1476ip tcp adjust-mss 1436tunnel sourc...
Hi there,I am using packet tracer and I have an issue with area A talking to area B or area B to area ACloud is configured to use modem4 to Ethernet6Server has DHCP on and can talk to router and other PC in area A but not area BArea A inside IP is: 1...
Hi AllI have a lab setup using DMVPN phase 3 with eigrp, a hub and 2 spokes.If I shut down the hub external IP, the spoke to spoke traffic fails within a few seconds.Is this normal? I know for redundancy you can have 2 hubs but would it still affect ...
i don't have ipv6 and only using ipv4. when i ping resolve ipv6 not ipv4Lab-Hub#ping yahoo.comType escape sequence to abort.Sending 5, 100-byte ICMP Echos to 2001:4998:24:120D::1:0, timeout is 2 seconds:% No valid route for destinationSuccess rate is...
I have router a with a gre tunnel (tunn 1)to router b. Gig 0/0/0 to Gig 0/0/0i need to make another tunnel from A to a third on router C. C is connected to B on gig 0/0/1. No routing protocols it’s a small network all static’s. What’s the best way to...
Hello Experts , I have a critical application traffic which passing though my Cisco ISR 4321 and i noticed that some packets being dropped as Taildrop , Please find below output from packet-trace debug : sh platform packet-trace summary | i Gi0/0/...
how can we view all the open ports on a router (if your sourcing from an outside IP) ?can we view open ports by using 'show' commands ? thanks.
Hi Guys, I know that the MOD80 LC is old and EOL but just wanted to double check if it can be working with ASR 9904 chassis. it is kind of an urgent router that must be deployed in one of the customer location and the customer has A9K-MOD80-TR and A...
Hello, if I had 2 Data Centers, each connected via BGP to our MPLS WAN carrier network. This MPLS WAN carrier network also contains a number of remote sites also connected via BGP. We’d like to have the two DCs be layer 2 adjacent through the MPLS ...
Hi team,i'm getting above mentioned log in NCS 540(N540X-6Z18G-SYS-A) and have checked isis it shows 2 directly connecting Neighbor and the MPLS it shows adding +2 . Please assist me.
Hello, everyone! I am currently studying DMVPN Phase 1 and I have a question about the following command: ip nhrp map multicast dynamic I understand that this is issued on the hub router/the NRHP server, but what exactly does it do? I was a little co...
Hi All, I have IP SEC tunnel from hsrp peer1 and dna advantage license activated on it and peer2 activated with right to use (RTU).Ill setup IP sla from peer2 towards peer 1 and will be tracked by EEPM applet.If Peer 1 goes down, then EEPM applet wil...
I recently got a cisco 2621 to act as a terminal server, which has a 32-ASYNC NM module attached. I made the configurations on the router to be able to access network devices using an octal cable via telnet [IP address] [port number]. This is the out...
We have pairs of N7K and N9k connecting via eigrp (full mesh), each one of the pair connected to two mpls routers, each pair have routing table, I am looking to replace the routed interfaces between pairs of N7K and N9K with vPC, is that possiable ? ...
Subject | Author | Posted |
06-14-2025 01:24 AM | ||
05-13-2025 03:49 AM | ||
05-12-2025 03:28 PM | ||
05-09-2025 02:25 PM | ||
05-05-2025 11:47 PM |
User | Count |
13 | |
9 | |
5 | |
5 | |
4 |
