Routing
Labels
Hi all, We have an IR1101 with a 5G modem. In logging we can see that it is constantly flapping between 4G and 5G and we want to lock it on 4G.We searched all documentation and tried all posibilities but nothing seems to work. Below some details. Log...
gwijnants by Level 1
  • 90 Views
  • 2 replies
hi all,  I'm wondering if its possible to route leak between 2 OSPF Instances running on different VRFs without using the GRT. I've not found much around asides from route leaking using a VRF and the global routing. A workaround would be from an OSPF...
alexb931 by Level 1
  • 2838 Views
  • 3 replies
Hello,I am having a weird issue which is either difficult or so easy I am missing it and wondering if I can get some help with this. I am working with an organization which has both staff users and public users. They use ROAS and L3 switches currentl...
pbiggs by Level 1
  • 181 Views
  • 6 replies
Hello,We recently had a failover test between between our ISP 1 and ISP 2. The failover portion worked fine via the IP sla's but we were unable to pass traffic through ISP 2. I believe the issue is due to the switch we have the ISP connections coming...
Adcom911 by Level 1
  • 259 Views
  • 11 replies
Hello everyone!I want to configure NAT-Hairpinning on the ASR-1002X router (17.09.05a, for this I went to the lab and tested the configuration on the CSR (17.03.08a). NAT-Hairpinning i need to allow internal clients allow access our external services...
quadzor by Community Member
  • 333 Views
  • 8 replies
Hi, We are using some old C881G-4G router with an LTE interface in remote location to gather data from sensors.Router has a two link types one is Ethernet and as backup we are using embedded LTE interface with a sim card an private APN and static IP ...
GregKK by Level 1
  • 253 Views
  • 4 replies
Hi GuysI saw an ISP router interface the other day with a route tag applied to the interfaceipv4 address 192.168.1.1 255.255.255.0 route-tag 5 commandWould this have been a Cisco router? if so what IOS?  I've never seen this command before on an inte...
Hi, I have installed packet tracer on a x64 Win 7 laptop and when i open the program it brings up a blank screen and wont allow me to login to the netacad, i have checked the requirements and updated java, flash and silverlight just in case but stil...
Hi there,I am using packet tracer and I have an issue with area A talking to area B or area B to area ACloud is configured to use modem4 to Ethernet6Server has DHCP on and can talk to router and other PC in area A but not area BArea A inside IP is: 1...
maxintime by Level 1
  • 876 Views
  • 17 replies
