07-25-2018 11:51 PM
Our access switches are covered under [Product ID - Unique Serial#] setup.
Ex:
Product ID: WS-C3750X-48P-S
Quantity: 10
Unique Serial Number: FDO1111111
** 10 C3750X are covered under this unique serial number.
Solved! Go to Solution.
07-29-2018 06:28 PM
Hello Anne,
I've received your reply via private message. Thank you for confirming the issue is resolved, please reach out again if you have any additional questions or concerns while using the SNTC portal.
Josh
07-26-2018 06:21 AM
The serial number FDO1111111 is not valid and is not showing in our records. It is not on any given contract so will show as not covered in the portal.
Are you certain this is the correct SN?
Regards, Tim
07-26-2018 04:46 PM
My apologies, Tim. My mistake.
The correct serial number is FDO1523V0ST.
We cold spare parts for replacement and our access switches are on Software support contract only - TAC, Software download, etc.
Cheers,
Anne
07-26-2018 07:13 PM
07-29-2018 06:28 PM
Hello Anne,
Josh
