comparision sheet between smartnet & Partner support
gyanendra
Hi Team,
Can you provide comparision sheet between smartnet & Partner support?
How can we show the difference between SNT & PSRT to the client?
balaji.bandi
closed match i found as per my understand is below :
https://www.proxar.co.uk/blog/cisco-partner-support-vs-smart-net/
partner can take care of this using different tools to provide reports.
BB
Thanks for sharing that comparison link from Proxar. It states PSS is more expensive than Smartnet - this is something which I experienced differently. For us PSS was always significantly cheaper than choosing Smartnet with the same SLA.
