CSPC Timesync Confusion
millerlw
Is this a bug or a feature?  Timesync appears to be working properly even though it's confused on whether it actually is or not, I just thought you should know.
Leonard
enrirami
Thank you for contacting Cisco.
I will check this internally, in the meantime, please provide the following information:
• Company name:
• Company address:
• CR Party ID:
• CSPC ID:
• CCOID:
• Email:
You can share the information via private message.
Kind Regards,
Enrique Ramirez
enrirami
• Company name:
• Company address:
• CR Party ID:
• CSPC ID:
• CCOID:
• Email:
Kind Regards,
Enrique Ramirez
millerlw
Apparently this has been reported as a bug
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwc98522
Thank you Enrique for your help,
Leonard
for now workaround is to set the correct time manually via linux commands connecting to collectorlogin and then # su root to get to root ( you may be able to do it on the prompt of collectorlogin user )
example :
# timedatectl set-time 'YYYY-MM-DD HH:MM:SS'
