08-23-2022 11:01 AM
From a quality of life perspective on the UI for Smart Net Total Care it would be ideal to be able to deselect multiple fields. I enabled all fields in a single drop down and performed an export to explore my data and then wanted to deselect the additional fields to return the field listing to the previous setting. During deselect I can only deselect one field and then I am forced to re-open the filed list and deselect the next field.
Solved! Go to Solution.
08-25-2022 01:32 PM
Hi John ,
Here is the resolution summary that we provided on the issue :
Thanks & Regards,
Kapil Taneja
08-23-2022 11:12 AM
Hi John ,
I am in-charge of this post and I will be assisting you on the issue . Please provide us the following details in Private message (PM )so that we can proceed further on the issue :
Thanks & Regards,
Kapil Taneja
08-23-2022 11:14 AM
This may be a "scale" issue. I added a filter to reduce the result set to a single serial number and then was able to remove fields from the field list by deselecting multiple fields without the dialog box closing.
08-25-2022 01:32 PM
Hi John ,
Thanks & Regards,
Kapil Taneja
