My Notifications displays No Email and my account does not have DA assigned
tim.harlan
Under the MY Notifications it will not let me select my email but my CCO has my correct email address.
No DA has ever been assigned on for my SmartNet Portal so I can add people to the portal.  Just completed installation and config with Cisco.
Suchita Shewale
Hi There,
You can use below URL to nominate a DA for your account
https://logcso.cloudapps.cisco.com/logcso/#/nominateDA
Regarding your other issue with My Notification, there is a bug in the system due to which My Notifications tab throws the error if the user CCO ID contains a dot  "." .
This issue is further getting addressed through bug CSCvh55219
As you are Customer Admin, you can set up the notifications from under Company Notification tab.
Please give this a try and let me know if there are any issues.
Suchita
Jarrett Pomeroy
Hello Tim,
Thank you for the details.
We found a bug in the system due to which My Notifications tab throws the error if the user CCO ID contains a dot  "." . This issue is further getting addressed through bug CSCvh55219.
Thank you,
Jarrett
Hi Tim,
The issue was noted as addressed in the latest release (SNTC 4.3).  Notifications can now be set as expected in the portal.
Cheers,
Cheri
