SNMP Walk
Cisco SmartNet
can you help what is the command of snmp walk to execute in the CLI of the collector?
regds,
9 Replies 9
taywelch
SNMP version 2 or 3?
Taylor
Both versions, please
SNMPv2c:
snmpwalk -v 2c -c ROCommunityString DeviceIPAddress
SNMPv3:
snmpwalk -v 3 -u Username -l SecurityLevel (AuthPriv/AuthNoPriv) -a AuthProtocol (SHA/MD5) -A AuthPasswd -x EncryptionProtocol (DES/AES) -X EncryptionPasswd DeviceIPAddress
Hi.
I am trying to run the snmpwalk command from the collector but the command is not available in the gui or via the cli. How can I run it?
Thanks.
Fred
balaji.bandi
collector ? cisco smart collector you mean ?
BB
Yes, the  CSPC Cisco
what is the version of smart collector, if you login root and you can run snmp walk as suggested other post.
BB
It is 2.8
Is there a default password for root? The only account I have for the collector is the initial one I setup when installing the collector.
I do not see root as a user in the gui.
Thank-you
you do not see user root in GUI, if setup intially you need to use same root password, or use rcovery for the root password proceedure.
BB
