10-29-2019 12:52 PM
Hi, Guys
I trying to install CSPC version 2.8 over Hyper-V, but there is a issue Cent OS 6.10 shell that installation freezes as picture below:
The installation stay on this screen and never change.
I deployed at Hyper-V cspc iso as recommend: 4 GB RAM, 4 v CPU and 250 GB Hard Disk, WIndows Server 2016
Solved! Go to Solution.
11-06-2019 08:04 AM - edited 11-07-2019 12:06 PM
I am now sending you a private message please use that link of a vhd file and try to install using it.
10-31-2019 06:37 AM
I had the same issue.
Leave the installation running for a night...
08-07-2020 02:43 AM
I have the same problem.
Can you help me?
Thank you,
Dan
08-27-2020 10:57 AM
Hi Adias,
I am having the same problem, could you send me the link with the vhd file?
12-13-2020 08:36 PM
Hello Adias,
I have the same issue in a Hyper-V environment. Can you help me with the information needed?
Thanks in advance.
