02-05-2018 04:31 AM - edited 03-12-2019 07:39 AM
I need to install a CSPC server in HyperV plataform. From what I checked in the documentation, this is possible, but I did not find any documents with the steps that I must follow with HyperV, I found only with VMWare. Is there a document that can help me step by step?
Leandro Barasniewski
Solved! Go to Solution.
02-05-2018 05:44 AM
Hello barasniewski,
Unfortunately, Hyper-V is not a currently supported platform for CSPC. We do offer a ISO image of the CSPC which may work for your use case, you can find ISO installation steps available here.
Thank you,
Jarrett
02-05-2018 05:44 AM
Hello barasniewski,
Thank you,
Jarrett
08-29-2018 01:55 AM
It seems that VMWare ESXi 6.0 kan be installed in a Hyper-V VM
https://www.vembu.com/blog/installing-esxi-6-0-in-a-hyper-v-virtual-machine/
I'm wondering if Cisco supports a CSPC installation in a nested ESXi inside a Hyper-V VM?
09-04-2018 08:03 AM
Hi Daniel,
Cisco has not certified CSPC to run on Hyper-V, therefore is not supported.
Cheers,
Cheri
