Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 2949 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4538 Views
  • 1 replies
  • 16 Helpful votes
I am currently testing 80 units (SF100D-05) and so far (after 20 units tested) 10 are not working properly.It's always 1,2 or 3 different ports that do not seem to connect properly (not status led on). On a single unit its always the same ports, but ...
Hello Everyone.  Thank you all for the help with my last post.  I have another wonderful problem that I've been trying to figure out myself for the last few days that I could really use some help with.  It turns out, that I have no idea how to set up...
shawny by Level 1
  • 1170 Views
  • 4 replies
HiApparently Cisco Small Business has come up with their own SFP(Mini-gbic) transceiver.http://www.cisco.com/en/US/products/ps9934/prod_models_comparison.htmlId like to know if the Cisco's version of GLC-SX-MM( SFP LC connector, SX transceiver) can b...
Hi All,I have the following equipments in my small network1x UC5604x IP Phones1x Catalyst 3560x as CoreSwitch2x ESW 540 as AccessSwitchI am trying to deploy a call recording feature on the VOIP UC system.The call recording solution i am using is the ...
Hi all,     I need to set a trunk between two SRW2048 connected over a fiber link, in order to let a vlan to be shared among them.  My configuration is:  switch A: - default untagged VLAN 1 - custom VLAN ID 10, named "wifi" - port 47=> fiber, set as ...
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
