Bookmark
Subscribe
1741
3G router 887G-K9 chat-script problem
Elena.Madrigal
Hello
I have a Cisco 887G-K9 with version 15.1-4 3G router,  I set up the router following the guidelines of cisco, but i cant stablish a succesfull connections, the router have the interface cellular 0 up with good RSSI, but when i force traffic to initiate the connexion the following error says
"line reset by Async Dialer"
I have attached my running-configuration( with sensitive info changed)   show cell 0 all output command and the error when chat-script initates the conection
Anybody could give me help?
Cheers!!
a few things were missing in your config, I have made some changes/additions (marked in bold). Also, try the different chat scripts, as well as encapsulation slip for the cellular interface:
hostname 3G_ROUTER
boot-start-marker
boot-end-marker
logging buffered 32000
enable secret 5 $1$D4wB$8Z6Yx5kdOrsHHGAJjTUli.
no aaa new-model
memory-size iomem 10
ip source-route
ip cef
ip domain name bme
no ipv6 cef
chat-script gsm "" "ATDT*98*1#" TIMEOUT 60 "CONNECT"
chat-script gsm "" "AT!CALL " TIMEOUT 60 "OK"
chat-script gsm “” “AT!SCACT=1,1” TIMEOUT 60 “OK”
license udi pid CISCO887G-K9 sn FTX102085QU
controller Cellular 0
ip ssh version 1
interface ATM0
no ip address
no atm ilmi-keepalive
interface FastEthernet0
switchport access vlan 196
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Cellular0
ip address negotiated
ip nat outside
ip virtual-reassembly in
encapsulation ppp/slip
load-interval 60
dialer in-band
dialer string gsm
dialer-group 1
async mode interactive
interface Vlan1
ip address 10.14.24.38 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 1 interface Cellular0 overload
ip route 0.0.0.0 0.0.0.0 Cellular0
ip route 10.144.0.0 255.255.0.0 10.144.24.254
access-list 1 permit 10.14.24.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line 3
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line vty 0 4
password admin
login
transport input all
end
hostname 3G_ROUTER
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
ip domain name bme
no ipv6 cef
ip ssh version 1
interface ATM0
no ip address
no ip address
no ip address
no ip address
no ip address
interface Cellular0
ip nat outside
load-interval 60
dialer in-band
dialer string gsm
dialer-group 1
interface Vlan1
ip nat inside
ip http server
control-plane
line con 0
line aux 0
line 3
exec-timeout 0 0
script dialer gsm
modem InOut
no exec
transport input all
rxspeed 7200000
txspeed 5760000
line vty 0 4
password admin
login
transport input all
end
