404 not found
Hello could you help me with this error help me with this error it does not let me enter the web console because I was trying to put a backup where it was not and now I can not get it to run the web error is 404 not found I have the switch catalyst 2960-X and here I leave a picture of my CLI witch the command "dir" executed.
Thanks.
29 Replies 29
Looking at the comments. -  You do not have external access from switch, that required to be fixed.
What IP of the device are you accessing?  - what is your PC IP you try to access http(s)://10.10.0.2
BB
to 10.10.0.2
What is the IP of your PC? Try to access http (s): //10.10.0.2
the ip of my pc is 10.10.0.22.
that's what I do and I get this
So you have web page access , that means you able to get http page from Cisco Swtich.
referring to your config, you do not have any username created with priv 15 here, (or may be missed due to many images.
username XXXXXXXXXX privilege 15 secret 5 XXXXXXXXXXXXXXXXX
ip http authentication  enable
ip http authentication local
and test
BB
What do I have to put and where?
what is this?
instead of images of the config - can you  issue show run from command level and attach here good and easy, so we can modify that and work.
Last message suppose to send this URL it was missed some how :
https://www.youtube.com/watch?v=iybitlJgctI
BB
no entiendo lo que quieres que haga
tampoco puedo conectar el ssh
ayudame mejor con el ssh y ya resolberemos eso luego
se puede insertar un backup desde teminal a un swicht que tiene la configuracion defaul
y el backup no esta en un servidor ftp ni nada esta en mi pc, si se puede hacer dime como porfa
it would be nice - if it can be English comment to help you..(i am poor in other language - sory).
BB
you can insert a backup from terminal to a switch that has the default configuration
and the backup is not on an ftp server or anything is on my pc, if it can be done tell me how please
if the config (show run or startup saved in PC) you can Open with notepad or notepad++ and you can read the config.
you can copy and paste on console directly. (make sure you add few lines at a time rather paste all lines.) see no errors.
test it and write the config.
BB
apogeenet
For SSH, did you generate a key (requires first setting a hostname and ip domain-name in the config)? I see an enable secret specified and line vty 0 only password.  Try this as a test and let me know if it works:
conf t
username admin priv 15 sec EasyPassword123
line vty 0 15
login local
priv 15
transport input any
crypto key generate rsa general-keys modulus 2048 label mykey
ip ssh rsa keypair-name mykey
end
then try to SSH and login with username admin and password EasyPassword123  (Caps sensitive).  If this doesn't work, place your laptop on the switch and assign it an IP on VLAN 1 in the DHCP network.  Is it possible your DHCP server is leasing out an IP with a bad net mask or gateway the conflicts with the default you specified?
ajoris
This solved my issue with 404 missing GUI on C2960x
https://community.cisco.com/t5/switching/catalyst-1000-web-gui/td-p/4808865
