Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
Dear community memebers,I need to test a scenario containing cisco nexus 9300 switches on a virtual lab. I tried to configure vpc on my switches both in eve and gns3. But I have a problem. I configured my switches, and the vpc is formed fine and is u...
elahe by Level 1
  • 2568 Views
  • 4 replies
HiIs it possible to operate a C9400-PWR-2100AC at 10A/230V? I only found the following specs for Input current for the C9400-PWR-2100ACInput current (rated):  ●  10.4A at 100 VAC ●  10.4A at 200 VAC https://www.cisco.com/c/en/us/products/collateral/s...
pf by Level 1
  • 107 Views
  • 2 replies
Hi, In a few days I will be upgrading our C9404R switch which has dual supervisors from 17.12.04 to 17.12.06. I have some questions on it. Is there a preferred method for this? Is ISSU upgrade preferred, although I hear people facing issues with this...
THussain by Level 1
  • 194 Views
  • 9 replies
Hi if add to uplink switchrouter bgp 65000address-family ipv4 unicastaddreggate address 192.168.0.0/24On all uplink Must be aggregate routes subnet 192.168.0.0/24 and onlyOne route announce to uplink 192.168.0.0./24Announce to uplink all routes inclu...
Hi I set core switch as VTP server. Error: VTP VLAN configuration not allowed when device is not the primary server for vlan database. VTP STATUS: VTP Version capable : 1 to 3VTP version running : 3VTP Domain Name : tre02-ITVTP Pruning Mode : Disable...
Hello. I have two questions about ICMP behavior and Fregmansion behavior. All system jumbo MTU / all interfaces / SVI are set to MTU 9216. 1. Packets are generated and processed by the ASIC (data plane) when pinged without a source When pinged to the...
moons by Level 1
  • 267 Views
  • 6 replies
Hi, Is there any clarity on whether CVR-QSFP28-SFP25G can be used with C9500-32C and C9500-32QC? I see support for CVR-QSFP-SFP10G in release notes for 16.10 but no documentation exists for CVR-QSFP28-SFP25G compatibility on TMG matrix or release not...
mandico by Level 1
  • 104 Views
  • 2 replies
I have this assignment where I need to make this work. I am new, and I've spent 5 days without understanding what I'm doing wrong and why it doesn't work. The topology must not be altered. I must use OSPF and change the addresses shown in the picture...
Yozhz by Community Member
  • 563 Views
  • 27 replies
      Hi guys I purchased a refurbished Cisco Catalyst 3850 switch to uplink back to a unifi dream machine for 2 APs and a proxmox server also possibly 3 Zimaboard 2 in a cluster down the road but my concern is the catalyst 3850 went into EOL back in...
Cmo33 by Community Member
  • 141 Views
  • 2 replies
Hello, On a Cisco 3850 switch, I have an SVI (VLAN 2). When I do show run int vlan 2 Vlan2 is up, line protocol is up , Autostate EnabledHardware is Ethernet SVI, address is 00b6.70c4.e177 (bia 00b6.70c4.e177)Description: Vlan 2 - XXXXXInternet addre...
abtt-39 by Level 1
  • 188 Views
  • 7 replies
