Cisco Switch models terms
zeeshanzahid510
Frequent Visitor
Frequent Visitor
Need guidance to clear the difference between following end terms in following cisco switch models,
C9200L-24P &&
C9200L-24T &&
C9200L-24PL &&
C9200L-24PXG &&
C9200-48PB
Wassim Aouadi
Level 8
Level 8
- C9200L have fixed uplinks and fixed fan trays. In C9200, uplinks are modular and fan trays are replaceable.
- Both can be stacked. But:
  • C9200L have max 80Gbps of stack bandwidth
  • C9200 have max 160Gbps of stack bandwidth
- "P" in the switch family name means "all access ports support PoE+"
- "T" in the switch family name means the switch does not have PoE capability.
- "PL" -> "partial PoE+". So not all ports support PoE+
- "XG" stands for Cisco multigigabit technology. You may need it when you deploy 802.11ac-capable access points attached to the switch.
ref: https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
Forum Tips: 1. Paste images inline - don't attach. 2. If you find a post helpful, please give it a thumbs up or mark it as a correct solution.
5 Replies 5
Wassim Aouadi
Level 8
Level 8
Thank you, but i can't find one thing that is "PB"
The "PB" model is very similar to the "P" model. The major difference I saw, when comparing two switches with similar port density, was that the "PB" family supports Enhanced VRF while the "P" does not. That information is found in Table 19 of the document I referenced in my previous reply.
Wassim
Another note - Cat 9200 not support many VRF as expected, as i remember it supports only 4 i guess. on the modular and 1 VRF on the fixed.
BB
balaji.bandi
All the information already covered here :
BB
