Connect a Cisco 2611 to internet using PPPoE
TheTrueMc128k
Hi all.
I'm new to the cisco IOS system. I'm also italian, so I can make mistakes while typing.
I have the following problem: I need to connect my router to the internet using a PPPoE Tunnel (it will act as a gateway). The router is connected to my ISP's modem via RJ45.
The router needs to connect like a PC, open session, username and password and so on. Nothing more. And the connection must be stable (when it's lost it automatically restarts the tunnelling)
I looked every guide I could find with no success... ping didn't work. This is my last try.
Thank you.
p.s.: one more thing... what's the best firmware for those kind of things? I need only pppoe, routing, dhcp, ntp, port mapping.
rizwanr74
Level 7
Level 7
This might help you....
interface dialer 1
ip address negotiated
encapsulation ppp
ip mtu 1492
ip nat outside
ppp authentication pap callin
ppp pap sent-username your-pppoe-user-name pass KING-OF_THE_Hill
dialer pool 1
exit
Interface FastEthernet0
no ip address
pppoe enable
pppoe-client dial-pool-number 1
no shut
exit
interface ethernet0
no shut
ip address
ip adjust-mss 1452
ip nat inside
exit
ip nat inside source list NAT-ACL interface dailer 1 overload
ip route 0.0.0.0 0.0.0.0 dialer1
paolo bevilacqua
If doesn;t work, you have configured somethign wrong. You can either have someone that know what he's doing fix it,
or try yourself reading monay, posts, documentation, and spending a lot of time.
rizwanr74
Level 7
Level 7
interface dialer 1
encapsulation ppp
ip mtu 1492
ip nat outside
dialer pool 1
exit
no ip address
pppoe enable
no shut
exit
interface ethernet0
no shut
ip address
ip adjust-mss 1452
ip nat inside
exit
              T H A N K    Y O U ! ! ! ! !
WORKED PERFECTLY!! Simply fantastic!!
Thank you again! You saved me from hours of googling.
