Environment , Cooling and electrical value calculation for nexus 9500 switches
noumanqazi
Good Day to All,
I am trying to calculate the " Environment factors like power and cooling variable for Nexus 9500 switches ( mainly 9516 and 9504) to calculate the facility requirements.
Electrical
Volts= Available in data sheets
Ø = Not available
Wires = Not clear
Amp= Available in data sheets
Cooling
KBTU/Hr = Available in data sheets
KW = Available in power tool
Tons= Not available in data sheets
CFM = Not Available in data sheets
Does any body have any idea how to find them.
Hello
In the data center, heat is often removed from the equipment by increasing the airflow, this is expressed in CFM, an increase in CFM equates to an increase in heat removal. There must be enough CFM that the equipment does not overheat. so the larger fan modules you have on the chassis the better cooling you will get for the chassis and its modules.
In other hand, talking about tons, remember that air contiditoning systems are rated in tons, so this refers to your data center cooling system, this is not actually the same if we talk about a Nexus chassis, you know that the role played by a fan module in the chassis is to take the cold aisle air flow, cool the internal components, thereby releasing the hot air from the chassis.
I am not an especialist in data center design, nevertheless I think you're trying to find information that is not concerned to the Cisco equipment, but to your data center cooling system desing. So this documentation could be useful for you.
https://www.cedengineering.com/userfiles/HVAC%20Cooling%20Systems%20for%20Data%20Centers.pdf
5 Replies 5
Deepak Kumar
I am not sure about cooling information but you can find power details here:
https://www.cisco.com/c/en/us/products/collateral/switches/nexus-5000-series-switches/datasheet-c78-730760.html?cachemode=refresh
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Dear Deepak,
This is a data sheet for 5000 series, but even in 9500 data sheet , not all the information are listed,
Like Theeta value.
For cooling I m more interested in finding the value of CFM and Tons, which I could not find in any data sheet.
Dear ,
I already gone through with this data sheet, but I did not find the information , which I requested in the thread.
Hello
