Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
Hi All,  I'm doing some self-guided Wireshark training on Udemy in order to better understand and troubleshoot my network. One of the topics today was retransmission, which I see a lot of in my captures and something I haven't been able to understand...
dbronco by Level 1
  • 204 Views
  • 4 replies
Dear community memebers,I need to test a scenario containing cisco nexus 9300 switches on a virtual lab. I tried to configure vpc on my switches both in eve and gns3. But I have a problem. I configured my switches, and the vpc is formed fine and is u...
elahe by Level 1
  • 3192 Views
  • 9 replies
Hi team, Sorry to bother you, I need to migrate Avaya switches Base Software version = v5.3.2.017 to Catalyst 9200 switches Ios Xe 17.12.6. Does anyone have any methods or equivalent commands? Thanks for your help.Ciro Gustavo Mele.
Hello FreindsAre there any things missed in the NTP server Below config? VMs has issue associating with this NTP ServerBelow NTP Config==============WS3750-X#sh run | sec ntpntp source Vlan64ntp master 5ntp server 172.16.100.254WS3750-X# 1 of the VM ...
I know it's a very silly question to ask, but I want to know whenever we create a vlan with vlan vlan-num e.g. vlan 10and then till we don't use exit and came back to configuration mode the vlan doesn't show up. Like why we have to explicitly 'exit' ...
When installing a new software version on a 9300 switch, a typical command is:install add file path:file.bin activate commitHowever, this requires some interaction (eg responding y/n) and it will be incomplete with out it. After which a reload is und...
C9300-48UN running IOS XE 17.15.04We have a new user onboarding shortly to the network team, and I want them to only be able to issue certain commands on our access switches.I have been testing multilevel admin access via the privilege command and no...
KL7476 by Level 1
  • 316 Views
  • 5 replies
Hi,My single SG350X-48P will be replaced by a SG550X-48MP stacked with a SG550XG-8F8T.Is it possible to backup the configuration of the 350 and import it into the 550x-48MP after building up the hybrid-stack?What is the recommended way/steps to trans...
Towin by Level 1
  • 190 Views
  • 3 replies
It's 2022 ! Most applications support dark mode and I feel like Cisco Packet Tracer should too. Opening Packet Tracer, I am greeted with a huge almost blinding white screen. Is there a way to enable Dark Mode in Cisco Packet Tracer 8 ? Thanks !
monish by Level 1
  • 97521 Views
  • 20 replies
  • 40 Helpful votes
