11-01-2018 02:39 AM - edited 03-08-2019 04:31 PM
Hello Experts,
is there is a special requirement for the USB drive which can be used to upgrade the IOS of the switches C9300-48P-E/C9300-48P-E ? in terms of capacity, formatting with FAT32 or NTFS etc.
please also provide the set of command which could be used.
11-01-2018 06:39 AM
01-20-2019 01:33 AM
It requires special USB from Cisco to connect with front-panel or use for 3rd party hosting applications, However, the workaround is to format the USB flash storage FAT32 to EXT4 in order to meet the internal requirements.
if it's still not recognizing the USB flash storage, please reboot the device and connect the USB with the hot-plug method.
if it's helpful please vote.
01-20-2019 04:18 AM
