Bookmark
Subscribe
5253
N5548 and GLC-T Not Supported
rtjensen4
Level 4
Level 4
Hi All,
Just got a new 5548 Switch, and to my surprise, the GLC-T I ordered with it do not seem to be working...
According to this link, it should work:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html#wp139256
Here's my show version:
Software
  BIOS:      version 3.5.0
  loader:    version N/A
  kickstart: version 5.0(3)N1(1b)
  system:    version 5.0(3)N1(1b)
  power-seq: Module 1: version v1.0
             Module 2: version v1.0
             Module 3: version v5.0
  uC:        version v1.2.0.1
  SFP uC:    Module 1: v1.0.0.0
  BIOS compile time:       02/03/2011
  kickstart image file is: bootflash:/n5000-uk9-kickstart.5.0.3.N1.1b.bin
  kickstart compile time:  4/3/2011 22:00:00 [04/04/2011 06:06:31]
  system image file is:    bootflash:/n5000-uk9.5.0.3.N1.1b.bin
  system compile time:     4/3/2011 22:00:00 [04/04/2011 13:20:24]
Hardware
  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor")
  Intel(R) Xeon(R) CPU         with 8299528 kB of memory.
  Processor Board ID JAF1515DBDJ
  Device name: DR-CORE1
  bootflash:    2007040 kB
Kernel uptime is 0 day(s), 1 hour(s), 9 minute(s), 3 second(s)
Last reset
  Reason: Unknown
  System version: 5.0(3)N1(1b)
  Service:
DR-CORE1# show int e1/15 transceiver details
Ethernet1/15
    transceiver is present
    type is 1000base-T
    name is CISCO-AVAGO
    part number is ABCU-5710RZ-CS4
    revision is
    serial number is AGM141223QL
    nominal bitrate is 1300 MBit/sec
    Link length supported for copper is 100 m
    cisco id is --
    cisco extended id number is 4
   Transceiver calibration is invalid
DR-CORE1#
From the output above,it seems to see the SFP, but it won't let me use it.
DR-CORE1# sh int status
Port          Name               Status    Vlan      Duplex  Speed   Type
Eth1/1        --                 sfpAbsent 1         full    10G     1/10g
Eth1/2        --                 sfpAbsent 1         full    10G     1/10g
Eth1/3        --                 sfpAbsent 1         full    10G     1/10g
Eth1/4        --                 sfpAbsent 1         full    10G     1/10g
Eth1/5        --                 sfpAbsent 1         full    10G     1/10g
Eth1/6        --                 sfpAbsent 1         full    10G     1/10g
Eth1/7        --                 sfpAbsent 1         full    10G     1/10g
Eth1/8        --                 sfpAbsent 1         full    10G     1/10g
Eth1/9        --                 sfpAbsent 1         full    10G     1/10g
Eth1/10       --                 sfpAbsent 1         full    10G     1/10g
Eth1/11       --                 sfpAbsent 1         full    10G     1/10g
Eth1/12       --                 sfpAbsent 1         full    10G     1/10g
Eth1/13       --                 sfpAbsent 1         full    10G     1/10g
Eth1/14       --                 sfpAbsent 1         full    10G     1/10g
Eth1/15       --                 sfpInvali trunk     full    10G     1/10g
Any thoughts? I've tried to look around for any solutions, but none are popping out at me. Thanks in advance!
Bug ID CSCsv02866 is not the problem. This bug only filed against the message "Transceiver calibration is invalid" in the show interface x/x transceiver detail command which is cosmetic.
The problem in the interface is not configured correctly. As per the output of the show interface status command:
Eth1/15 is set to 10G (default) instead of the speed of the SFP which is 1GE. To correct this issue, use the command speed 1000 and duplex full under interface configuration mode.
int e1/15
speed 1000
duplex full
Verify it with show interface status and show interface e1/15 transceiver detail.
HTH,
jerry
I got it worked out, thanks! Turns out I have to set speed BEFORE inserting the SFP. The 'speed' command isn't available when it is in. I just had to remove the SFP, set speed 1000, then re-insert SFP. Seems odd / hokey to me, but hey, it works.
HI,
An other solution is to conf the interfaces in range mode and set speed to 1000 without unplugging the SFP's
command speed has been accepted
Model N5548P
  kickstart: version 5.0(2)N2(1)
  system:    version 5.0(2)N2(1)
it seems to be a workaround within a bug
BR
Raffaele G.
