Switching
Labels
Welcome to the Cisco Community Ask Me Anything conversation. Submit your questions from Monday, February 2, 2026, through Friday, February 20, 2026. Our colleagues Amruta Navadagi, Anaya Kalawat, and Mohammad Mehtabuddin will be waiting to assist you...
amnavada by • Cisco Employee
  • 14881 Views
  • 29 replies
  • 2 Helpful votes
CISCO C9500 32C has no uplink ports, so is the case like it cannot be used in access or Distribution layer? Also, Is it necessary that   Uplink ports must be always SFP ports? ( Since we have to use fibre optic cable for uplinking)
Hey all,Can i configure two port of a same switch for redundancy of ISP which is 9300 L3 switchi am having two isp and also two L3 switch but both of them is need to be connected in stack and also i need to configure HA for Both these ISP is there an...
Hi,few month ago 17.15.5 turned to be the recommended IOS-XE version and now with these vulnaibility there should be an upgrade from it. what do you recommend and advise? 17.18.4, 17.15.6 or anything ?https://sec.cloudapps.cisco.com/security/center/c...
I don't want to steal anybodies time... Just found - after 15 years using those devices in depth, teaching several QoS-Classes - nobody noticed that, really?"60 - 64" - ... DSCP 64? So beautiful!https://www.cisco.com/c/en/us/td/docs/switches/lan/cata...
Important alertsMS130-24(P) switches will reboot twice during the upgrade process when transitioning to MS 18.1.8 (or later) from MS 18.1.7 or earlier. This behavior is expected, and is not indicative of a problem.New feature highlightsGroup Policy A...
Raphael_L by • Meraki Community All-Star
  • 1077 Views
  • 8 replies
  • 1 Helpful votes
I bought a Cisco Catalyst switch from a hamfest (amateur radio swap meet) and am trying to get it working.  I am a retired software engineer and am just looking to get this working.  I can connect to it through a serial conection and can run some ini...
Hi Cisco Community,I would like to clarify the StackWise compatibility between the original T3 stacking hardware and the newer T3A hardware for the Cisco Catalyst C9300L-24P-4G.We currently have both of the following stacking kits available:STACK-KIT...
Jenson106 by • Community Member
  • 250 Views
  • 1 replies
I know this is an older thread but I get the following when trying to enable this guestshell. Any ideas? #guestshell enableInterface will be selected if configured in app-hostingPlease wait for completion% Error: No interface configuration for guests...
MFLauder by • Level 1
  • 201 Views
  • 1 replies
I'm looking for Cisco Letter of Volatility for this Cisco 48-Port Network Switch Part # C9200L-48PL-4G-E. This Cisco Letter of Volatility will include all the Volatile Memory, Non-Volatile Memory, Media and how to properly sanitize and erase the memo...
Samer3310 by • Community Member
  • 215 Views
  • 1 replies
