Bookmark
Subscribe
3568
Port goes down and up every 10 minutes
Wesker
Hi, recently I've connected UPS APC to our network and seem Cisco Catalyst 9300-48P port where it is connected goes down and then up every 10 minutes. When I start pinging the end device (APC UPS) indefenetrly from my laptop, "flapping" stops, it does seem like when there is no network activity UPS(or switchport) resets every 10 minutes. I've checked port config, there is no power saving etc. To tesk, i enabled LLDP on the port, to make it send LLDP packets, but nothing change in regard top down/up situation, anyone has suggestions?
P.S.
end device (UPS) firmware updated.
2 Accepted Solutions
Deepak Kumar
I found a similar issues: https://www.reddit.com/r/sysadmin/comments/ttdqyx/what_happens_when_you_deploy_apc_smartups_nmc3/
Last time this helped me.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
It seems there is some discussion around watchdog causing the reboot every 10 minutes, which perfect fit to your scenario.
If you are able to, Id get the vendor onboard but if you can not, you can try do by yourself. Here is the link.
https://community.se.com/t5/APC-UPS-Data-Center-Enterprise/AP9641-reboots-every-10-minutes/td-p/396711
7 Replies 7
   Can you share the exact UPS model?  I´d say that this is a UPS behavior as for the switch it does not cut connectiviry due port inactivity.
Leo Laohoo
That sounds like the NIC of the UPS is crashing.
Wesker
I've updated to the lastest firmware, we have about 15 UPS'es with same problem.
UPS Model is :
Smart-UPS SRT 2200
Network card :
Model Number
AP9641
Logs from UPS web interface:
Do you have any Cisco VoIP handsets?
Deepak Kumar
Deepak Kumar,
Wesker
Wow....thanks guys a ton...all fixed with NMS factory reset after fw upgrade,  ..APC manual misssing this part (about NMC factory reset), I was with their support for a month bouncing emails back and forth until you helped me.
https://www.apc.com/us/en/faqs/FA156047/
