Switching
Labels
Hello, Cisco Community!I’m really happy to share that I’ll be hosting the Cisco Community Lab Series, a brand-new hands-on learning journey designed to help you build practical networking skills step by step.Every Thursday at 8 PM EST, I’ll post a ne...
Reporting a bug: My team and I have discovered a bug associated with cat9k_iosxe.17.15.04.SPA.bin. We began testing the version to roll-out as it is now the gold star, and found that when a Cisco VOIP phone (any model really, we tested conference pho...
Hello, Im trying to resgister our new catalyst 9200L switch, but the command license smart register idtoken not supported on IOS 17.15.03.SW#license smart register^% Invalid input detected at '^' marker. SW#license smart ?authorization Authorizationc...
INFR1 by Community Member
  • 118 Views
  • 1 replies
It took me a long time to find out why I couldn't connect to my Cisco C1000-8p switch. Turned out that the port-channel set up with GLC-LH-SMD SFP's does not work. When we remove the port-channel and connect over a single trunk setup the connection w...
Nout by Level 1
  • 330 Views
  • 4 replies
I have the following problem.My Wake-on-LAN (WOL) works throughout the entire building.Now I had to install an edge node behind another edge node.Strangely, WOL no longer works on the second edge node.Has anyone had this problem before?I suspect that...
I just received 2 brand new C9200CX switches to put to use at my business. Unlike the other switches I have on property this one has the micro USB port for the serial connection. I have downloaded and installed the USB driver from Cisco. I am unable ...
Fred C by Level 1
  • 5963 Views
  • 10 replies
Hello switching experts! I have deployed a pair of Cat 9300 switches i.e 9300-48T-E running IOS 17.9.4. These switches are stacked. Everything is working fine. However, a strange issue is being faced i.e. switch is unable to ping its local SVI. The p...
Hello,We have a SVL pair of Catalyst 9500 running as a core switching system. The DAD link goes via Catalyst 9300 aggregation layer switches configured in stack.We are wondering, if we reboot the 9300 stack as a part of an upgrade process, if this wi...
