Switch Catalyst 3560G Web Interface Problem
fabienfs
Level 2
Level 2
I have a problem with my Cisco Catalyst 3560G switch. The web interface does not work (I tried IE11, IE6, Chrome, Firefox and Safari).
There is only displayed icons but no text :
To try to solve the problem, I've updated the switch to its latest IOS version (from 12.2(55)SE7 to 12.2(55)SE9). But the problem persists
WS-C3560G-48TS     12.2(55)SE9           C3560-IPBASEK9-M
In the configuration, the web server is enabled:
ip http server
ip http secure-server
What can I do?
Best Regards,
Fabien
2 Accepted Solutions
Hi Fabien,
for using the GUI , you have must have permission of privilege level 15 access
create a user
==>1
username admintest privilege 15 privilege 15 secret admintest
then runn the http services
==>2
ip http server
ip http authentication login local
==>3
management ip
http://xx.x.x..xx.x.x
it will ask you username and pass
make sure you have updated java version and follow attached pic
rate it if help full
BR
SYED
Hello Fabien,
I think i have found the problem and a workaround for that.
The problem comes from the language of the webbrowser.
I had exactly the same problem with the same model with the same IOS version.
I have inspected with debugging tools in firefox and I find, the browser want to get  (firefox in french for my case) 2 scripts :
http://<ip switch>/fr/charset.js
http://<ip switch>/fr/re_preflight.js
But there is not any fr folder in flash:/C3560.......
So I have changed preferred language in firefox (putting english in first). Reload webpage and it works fine 😉
I hope it will help you
Jeremy
26 Replies 26
Reza Sharifi
Try loading the latest version of Java and than test again.
I installed the latest version of Java (https://www.java.com/fr/download/win8.jsp).
The problem remains the same
Hello Fabien,
Jeremy
Hello Jeremy,
Yes, it works!
Is it not possible to create a directory /fr/ with English files into for not having to change the language of naviguator ?
Also , In interface I do not click on the left menu, the menu not work. Have you also this problem on Firefox ?
Fabien
Yes I have the same problem with the left menu in Firefox. It doesn't work .
I haven't ever tried to create a fr folder and copy paste files from /en folder.
I'll keep you in touch, when I'll realize the test.
Thank you for this tips 😉
you can patch your .tar file
in my case i just copy html/en to html/fr
now i can load webpage on my French browser.
if not show correctly just change language box to china and come back to english.
If someone can found multilanguage tar file say to me.
i know i have other 3750 switch whitout this problem but now i use 3750-X... i will check what is the firmware version.
 i disable https and just keep http to skip the first page.
For me this firmware is a really bad work from cisco...
Hi Fabien,
create a user
==>1
==>2
ip http server
==>3
management ip
BR
SYED
fabienfs
Level 2
Level 2
Hi aman,
Thank you for your reply.
We advance, but there is still a problem :
Config :
username adminweb privilege 15 secret 5 $1$pnSK$3HooqgcPV5WpjVPrXvoPu/
ip http server
ip http authentication local
I also set intranet security in IE.
What's missing?
Fabien
Dear Fabien,
try to check on another pc, and make sure the following thing on PC
==>1 Latest IE browser (please check the attachment for security setting)
==>2 latest version of Java install ( please check the attachment for Java Setting)
==>3 check PC firewall allowed program for testing ( best to be off the PC firewall)
BR
SYED
I disabled the firewall and apply all settings, but without success.
IE : 11.0.9600
Java : Version 8 MAJ 25
All programs are up to date
See attached
Same thing from another pc 😞
Post the output to the command "dir".
I am suspecting the IOS was upgraded by copying the BIN file and not a total "unpack" of the TAR file.
Hello Leo,
SwitchBureau#dir
Directory of flash:/
    2  drwx         192   Mar 1 1993 00:12:57 +00:00  c3560-ipbasek9-mz.122-55.SE9
    3  -rwx        8139   Mar 1 1993 15:25:10 +00:00  config.text
  499  -rwx        1036  Oct 22 1993 00:16:56 +00:00  vlan.dat
  500  -rwx         106   Mar 1 1993 00:14:42 +00:00  info
  502  -rwx        1938   Mar 1 1993 15:25:10 +00:00  private-config.text
  503  -rwx        3096   Mar 1 1993 15:25:10 +00:00  multiple-fs
32514048 bytes total (17069568 bytes free)
And in "c3560-ipbasek9-mz.122-55.SE9" directory :
SwitchBureau#dir flash:c3560-ipbasek9-mz.122-55.SE9
Directory of flash:/c3560-ipbasek9-mz.122-55.SE9/
    4  -rwx    11772212   Mar 1 1993 00:12:57 +00:00  c3560-ipbasek9-mz.122-55.SE9.bin
    5  -rwx         505   Mar 1 1993 00:12:57 +00:00  info
    6  drwx        4800   Mar 1 1993 00:14:41 +00:00  html
I used this command to install the latest IOS :
archive tar /xtract tftp://10.30.0.2/c3560-ipbasek9-tar.122-55.SE9.tar flash:
Thanks, Fabien.
I can't really see the date and time stamp of the HTML folder.  Also, I know the command "/xtract" works because I used to use it.  For the sake of argument, can I ask you to do the following commands:
1.  delete /f /r flash:c3560-ipbasek9-mz.122-55.SE9/
2.  archive download-sw tftp://10.30.0.2/c3560-ipbasek9-tar.122-55.SE9.tar
And when the unpacking is complete, reboot the appliance and try again.
The problem remains the same 😞
Here is the log of the update : http://pastebin.com/8HHBXVxk
What's weird is that by looking at the HTML source of the web GUI, I get errors in javascript. See here: http://pastebin.com/J8NpwwDy. Normal ?
thanks
