Switch
CSCO10320953
Level 4
Level 4
You are about to configure fast ethernet on an adapter to connect to a switch. What are valid configuration pairs?
Switch: Autoneg On -?Client: Autoneg On
Switch:?100HD -?Client: Autoneg On
Switch:?100FD -?Client: Autoneg On
Switch:?100FD -?Client: 100FD
6 Replies 6
ankbhasi
Hi Friend,
The best combinations are
Any of the 3 above combinations work fine. But sometime auto auto on both sides does not work well due to negotiation problem on link so you can keep any of the 2
and it will work fine.
Ankur
*Pls rate helpfull post
Friend,
I would like to add to the above post, that if you hard code any one side and keep the other side to autonegotiate, the link always will work on Half Duplex.
So i dont think it is a best option.
Narayan
I would disagree with the switch as 100/FD and the client as auto this creates a speed/duplex mismatch as the client side will default to 100/half. This will cause problems ...
jeff.teoch
Community Member
If you hard code on switch, it's best for you to hard code on client as well. As for servers, it's best practice to hard code both sides.
mahmoodmkl
Level 11
Level 11
I agree with royalblues as if u hardcode one end and leave the other end to auto it will be half-duplex.
Mahmood
schm196
Level 4
Level 4
Auto/Auto and 100FD/100FD are the only valid configurations, with preference to 100FD/100FD fix configuration when using third-party NICs that may run into auto-negotiation issues. Forcing one end to a fix setting causes alignment errors, FCS errors, or late collisions on the interfaces if the other is left to attempt auto-negotiation. See http://www.cisco.com/warp/public/473/53.shtml#SpeedDuplex_mismatch for the official take on this.
