Two DHCP servers for data and voice
dumble4me
I have switches having data vlans and voice vlans. My switchport is configured with "switchport access vlan x" command and "switchport voice vlan y".
Now I want voice vlan to take DHCP address from Call Manager, here DHCP is configured in Call Manager. Data vlans should take IP address from my Enterprise DHCP server. Is this possible ?
Pete
8 Replies 8
m.matteson
Level 2
Level 2
you could have both your data devices and your voice devices point to the same dhcp server. let's say you have two vlans, 1 & 2. what you would do is configure two DHCP scopes on your DHCP server, 192.168.1.0 and 192.168.2.0. with VLAN/SUBNET 1 being for data and VLAN/SUBNET 2 being for voice. All you have to do now is configure an dhcp relay address on whatever interface your using to route your vlans. this could be "interface vlan 1" (this would be a SVI) or a subinterface on a router. use the command "ip dhcp-helpder address" and enter in the address of your dhcp server. I would assume that your dhcp server is located on your data network so you would only have to enter this command onto the routable vlan interface for your voice subnet.
Thanks for the reply.
But What I want to use is have 2 separate DHCP servers for Voice and Data Vlans.
I want to have Call Manager to be the DHCP server for the Voice Vlans. Is it possible ?
Pete
To forward the DHCP request from the differenet vlan to two differenet server all you need to do is define Helper-address accordingly on both the vlan.
for eg:-
int vlan 1
ip helper-address <1.1.1.1> first DHCP server
int vlan 2
ip helper-address <2.2.2.2> second dhcp server
http://cco.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a00800f0804.shtml#configdhcpbootpciscoios
HI
Just to add make sure that u have appropriate scopes configured on the dhcp servers.
Mahmood
Amit Singh
Pete,
that is possible and certianly you can do that. just set the correct "Ip helper-address" for the respective DHCP servers under the voice and data vlan SVI's.
HTH,Please rate if this does.
-amit singh
Thanks for your reply. Can you tell me what all additional scopes/configurations I need to configure in DHCP for the Voice Vlans ?
Pete
HI
Make sure that u enable tftp option in u r voice vlan scopes.I think it is 150 something.
Mahmood
Configuring the CM scope is pretty straight forward. Set at least the correct default gateway and tftp server option 150 (pointing to the CM running the tftp server). You might setup dns settings but this is not mandatory for a basic setup.
