C40 not pairing with Touch 12
warillo
I am having difficulties pairing a touch 12 with the C40 codec.
C40 is currently running 7.0.2
Wilfred
2 Accepted Solutions
Jonathan Robb
Hi Wilfred,
To confirm, is this a Touch12 or a Touch 8?  Touch 12 would only be supported on a CTS/TX endpoint - CTS-1300, TX9000, etc.
-Jonathan
Wayne DeNardi
As per the Data Sheet, the Touch 12 doesn't work on a C40 codec.  You'll need to use a Touch 8, and in particular a CTS-CTRL-DVC8=.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
amehla
Hi Warillo,
could you elaborate it a bit more ?
how the touch is getting IP information ?
Jonathan Robb
Hi Wilfred,
-Jonathan
Wayne DeNardi
Wayne
Wayne
Yes that seems to be the issue. I was using a T12 and replaced it with T8/T10 and now its working.
Thanks for the help.
