Codian 8510- Unexpected reboot
ginowrief
MCU : Codian MSE 8510 Blade (configured in HD mode)
Software version : 4.2(1.46)
Build: 6.17(1.46)
The bridge has been rebooted unexpectedly this morning and we are actually investigating this problem. I would appreciate if you can help me and provide some ideas to identify this problem.
We suppose that it is an electrical factor as on the MSE Supervisor 8050 ,there is an error message:
Insufficient current capacity (requires at least 24.20A)
Do you think that there is a relation with this error message?
2 Accepted Solutions
Saurabh Gupta
Level 3
Level 3
Hi Firdaush,
Could you please provide some background information :-
  • Is it a new installation?
  • Was it working before?
  • Have you calculated the power requirements when installing it for first time correctly?
  • how many blades are there in the chassis?
  • Could you also attach some brief snapshot of the event logs of the MCU.
Saurabh
I do believe the efficiency is 90-92% on that H Series rectifier.  Even at 90% will tell you, you will require 2 rectifiers to run that chassis.  But since you only have one, like I said, will generate the insuffcient capacity warning.
VR
Patrick
14 Replies 14
Saurabh Gupta
Level 3
Level 3
Hi Firdaush,
Saurabh
Hi Saurabh,
Sorry, its not the correct answer. Please maintain the request.
Patrick Pettit
HI Firdaush.  How many rectifiers do you currently have in the powershelves right now? A and B? How many blades you currently running in this chassis?
Snapshot of Hardware>Blades and Hardware>Power Supplies would be helpful.
If the blade rebooted on its own, you can download the diagnostic.zip file at the bottom of the status page and more likely open a TAC case if you want to.  If you want to post it here, thats up to you.
This message, to me is indicating you don't have enough capacity to run what you have slotted in the chassis. It depends on what shelf is reporting this also.
This may or may not be the cause of the issue, and hopefully the diagnostic.zip file will show something, or why it occurred.
VR
Patrick
Hello Patrick,
ShelfTypeReported informationStatus AValere Mini DC / NIC1000
RectifierVoltageCurrentCapacityStatus
153.99V4.14A21.00A0807-OK
254.07V1.71A21.00A0807-OK
3---Not present
4---Not present
OK BValere Mini DC / NIC1000
1---Not present
2---Not present
3---Not present
453.95V9.12A21.00A0807-OK
ginowrief
No, intall since 2011
YES
YES
Events log MCU:
        1 2013/03/01 09:11:10.200 SYSTEM                  Info      Codian MCU 8510 4.2(1.46) (Build 6.17(1.46)) starting
        2 2013/03/01 09:11:10.200 SYSTEM                  Info      device configuration successfully loaded
        3 2013/03/01 09:11:10.868 NETWORK                 Info      SSL successfully initialised
        4 2013/03/01 09:11:10.875 NETWORK                 Info      DTLS successfully initialised
        5 2013/03/01 09:11:10.892 SYSTEM                  Info      Disabling core dumps
        6 2013/03/01 09:11:10.892 UPGRADE                 Info      clearing local features cache
        7 2013/03/01 09:11:10.898 CLUSTER                 Info      feature enabled
        8 2013/03/01 09:11:10.961 NETWORK                 Info      network_control_init
        9 2013/03/01 09:11:10.979 NETWORK                 Info      Initialising IP routes
       10 2013/03/01 09:11:11.091 NETWORK                 Info      activating ethernet Port A with auto-negotiation
       11 2013/03/01 09:11:11.105 NETWORK                 Info      activating ethernet Port A with auto-negotiation
       12 2013/03/01 09:11:11.116 NETWORK                 Info      deactivating port A IPv6
       13 2013/03/01 09:11:11.116 NETWORK                 Info      activating ethernet Port B with auto-negotiation
       14 2013/03/01 09:11:11.127 SYSLOG                  Info      sending from default port 514
       15 2013/03/01 09:11:11.128 NETWORK                 Info      activating ethernet Port B with auto-negotiation
       16 2013/03/01 09:11:11.131 UPGRADE                 Info      Hardware compatibility: 00000001 / ffffffff
       17 2013/03/01 09:11:11.143 NETWORK                 Info      deactivating port B IPv6
       18 2013/03/01 09:11:11.146 NETWORK                 Info      activating ethernet Port A with auto-negotiation
       19 2013/03/01 09:11:11.148 NETWORK                 Warning   cannot get network services configuration for interface: dbgname: bogus NETINTERFACE
       20 2013/03/01 09:11:11.149 NETWORK                 Error     Connect failed with errno 51
       21 2013/03/01 09:11:11.149 TMS_FEEDBACK_EVENTS     Warning   Notifier (index: 1) unable to connect to 53.154.21.111:80 for sending event notification
       22 2013/03/01 09:11:11.171 USER_MANAGER            Info      15 users present
       23 2013/03/01 09:11:11.173 NETWORK                 Info      activating port A IPv4 with fixed IP parameters
       24 2013/03/01 09:11:11.179 CUSTOMIZATION           Info      customisation configuration read; starting with 1-off 2-off
       25 2013/03/01 09:11:11.191 CUSTOMIZATION           Info      Doing customisation resources init
       27 2013/03/01 09:11:11.196 NETWORK                 Info      activating ethernet Port B with auto-negotiation
       28 2013/03/01 09:11:11.222 NETWORK                 Info      deactivating port B IPv4
       29 2013/03/01 09:11:11.247 NETCONF                 Info      Renewing DHCP on all interfaces to propagate host name
       30 2013/03/01 09:11:11.288 SYSTEM                  Info      default text tokens loaded - 6427 tokens (UTF-8 format)
       31 2013/03/01 09:11:11.301 RECORD_STORAGE          Info      record_storage module initialised
       32 2013/03/01 09:11:11.303 CDR                     Info      CDR storage available
       33 2013/03/01 09:11:11.303 CDR                     Info      Finding archived sections
       34 2013/03/01 09:11:11.589 CDR                     Info      Finding current sections
       35 2013/03/01 10:11:12.554 CDR                     Info      Current sections OK
       36 2013/03/01 10:11:12.555 AUDIT                   Info      Audit storage available
       37 2013/03/01 10:11:12.555 SYSTEM                  Info      Unique id change thread starting
       38 2013/03/01 10:11:12.589 SYSTEM                  Info      Unique id initialised
       39 2013/03/01 10:11:12.589 SHELL                   Info      Serial shell unsecured
       40 2013/03/01 10:11:12.605 CAPABILITIES            Info      Creating 310 capability sets
       41 2013/03/01 10:11:12.821 SIP                     Info      SIP initialised
       42 2013/03/01 10:11:12.979 H.239                   Info      init
       43 2013/03/01 10:11:12.981 AUTO_ATTENDANT          Info      initialised - 1 present
       44 2013/03/01 10:11:12.998 API                     Info      initialised database
       45 2013/03/01 10:11:13.628 AUDIT                   Error     Audit log failed to shutdown correctly in previous boot, audits dropped.
       46 2013/03/01 10:11:13.642 AUDIT                   Info      Reading hashes of audit log
       47 2013/03/01 10:11:13.642 AUDIT                   Info      Calculating file hashes and checking against read hash
       48 2013/03/01 10:11:13.642 AUDIT                   Info      Completed Audit hash check
       49 2013/03/01 10:11:21.357 NETCONF                 Info      media connect on vfx0 (3)
       50 2013/03/01 10:12:13.410 SYSTEM                  Info      Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
       51 2013/03/01 10:12:13.528 SYSTEM                  Info      Successfully opened file and read starting id as 32000
       52 2013/03/01 10:12:13.588 SYSTEM                  Info      Unique id "conference_id" was written; new allocation is 34000
       53 2013/03/01 10:12:13.593 GATEKEEPER              Info      settings changed - registering all
       54 2013/03/01 10:12:13.594 SIP                     Info      Starting SIP TCP service
       55 2013/03/01 10:12:13.605 SIP                     Info      Starting SIPS TCP service
       56 2013/03/01 10:12:13.605 SIP                     Info      Starting SIP UDP service
       57 2013/03/01 10:12:13.729 NETWORK                 Info      Registering tunnel prefix with http handler
       58 2013/03/01 10:12:13.730 WEB_PAGES               Info      page services initialised
Patrick Pettit
Yeah. You may need to verify and add a 2nd rectifier to shelf B if possible.  What type of blades are they? All 8510's?
I'd check to see if you have another rectifier, and add it to shelf B.
The reboot is a different story, unless the diagnostic.zip file is looked at to be sure.  Hopefully it will shed some light.
VR
Patrick
Patrick,
1 Codian MSE Supervisor 8050
2 Codian MSE 8510
3 Codian ISDN GW 8321
4 TPS 8710
Unfortunately, i won't be able to send you the diagnostic file as it contains confidential information. Sorry.
Patrick,
Is there any docs explaining to decode the diagnostic file contents ?
Patrick Pettit
HI Firdaush.  No, there are no docs for that file.  This is used for TAC and BU purposes only.  If you were to raise a case with Cisco TAC, this file would be needed to try hopefully see what happened.
Reference the insuffcient capacity issue, you can check the calculator page cause right now, if shelf A went down or lost power, shelf B, doesn't have enough power to run the chassis.
You can run the calculator here:
http://www.cisco.com/en/US/docs/telepresence/infrastructure/articles/mse_8000_calculate_power_current_requirements_kb_386.shtml
90% efficiency on the rectifiers, you will require 2 rectifiers to run the chassis, but since B only has one, and if A were to go down, I don't believe you will have enough power to power the chassis.
VR
Patrick
How to know the effeciency of the rectifier?
VR
Patrick
Perfect.
But do you think that the reboot is due to the incapacity electrical problem?
Patrick Sparkman
Nothing like a forum discussion to get you thinking about your own infrastructure and it's salability currently in the in the future when you're thinking about adding additional blades.
I have one question on the power rectifiers as the amount of rectifiers in my shelves are the same as Firdaush's.  We have two (2) rectifiers in shelf A and one (1) in shelf B, we currently only run one (1) 8510 blade but are looking to add an additional 8510.  If I'm calculating this correct, I would need to add another rectifier to shelf B for redundancy just in case A went down, correct?
Can someone tell me what the rectifier efficiency means as well?
Thanks, and sorry for butting into the regional discussion, but thought it was around the same lines and possible preventative measures as what was mentioned previously here would apply to my question.
@Firdaush - Not sure without checking out the file which I'm hoping would tell us what happened, but I can't be sure.  If you want, you can open a case for investigation if you would like us to.  The other rectifier would be important for you to look into also.
@Patrick. Yes, if you add additional blade to your chassis, use the calculator to see how many more rectifiers you may need here. Keep in mind redundancy also.  In case you need more on the other shelf as well.
Attached is the H-Series Rectifier data sheet if you need to know more about the efficiency etc.
VR
Patrick
