03-01-2013 03:55 AM - edited 03-18-2019 12:42 AM
MCU : Codian MSE 8510 Blade (configured in HD mode)
Software version : 4.2(1.46)
Build: 6.17(1.46)
The bridge has been rebooted unexpectedly this morning and we are actually investigating this problem. I would appreciate if you can help me and provide some ideas to identify this problem.
We suppose that it is an electrical factor as on the MSE Supervisor 8050 ,there is an error message:
Insufficient current capacity (requires at least 24.20A)
Do you think that there is a relation with this error message?
Solved! Go to Solution.
03-01-2013 04:08 AM
Hi Firdaush,
Could you please provide some background information :-
Saurabh
03-01-2013 06:54 AM
I do believe the efficiency is 90-92% on that H Series rectifier. Even at 90% will tell you, you will require 2 rectifiers to run that chassis. But since you only have one, like I said, will generate the insuffcient capacity warning.
VR
Patrick
03-01-2013 04:08 AM
Hi Firdaush,
Saurabh
03-01-2013 05:07 AM
Hi Saurabh,
Sorry, its not the correct answer. Please maintain the request.
03-01-2013 04:43 AM
HI Firdaush. How many rectifiers do you currently have in the powershelves right now? A and B? How many blades you currently running in this chassis?
Snapshot of Hardware>Blades and Hardware>Power Supplies would be helpful.
If the blade rebooted on its own, you can download the diagnostic.zip file at the bottom of the status page and more likely open a TAC case if you want to. If you want to post it here, thats up to you.
This message, to me is indicating you don't have enough capacity to run what you have slotted in the chassis. It depends on what shelf is reporting this also.
This may or may not be the cause of the issue, and hopefully the diagnostic.zip file will show something, or why it occurred.
VR
Patrick
03-01-2013 05:03 AM
Hello Patrick,
ShelfTypeReported informationStatus AValere Mini DC / NIC1000
Rectifier | Voltage | Current | Capacity | Status |
1 | 53.99V | 4.14A | 21.00A | 0807-OK |
2 | 54.07V | 1.71A | 21.00A | 0807-OK |
3 | - | - | - | Not present |
4 | - | - | - | Not present |
OK BValere Mini DC / NIC1000
1 | - | - | - | Not present |
2 | - | - | - | Not present |
4 | 53.95V | 9.12A | 21.00A | 0807-OK |
03-01-2013 04:51 AM
Is it a new installation?
No, intall since 2011
Was it working before?
YES
Have you calculated the power requirements when installing it for first time correctly?
YES
how many blades are there in the chassis?
Events log MCU:
1 2013/03/01 09:11:10.200 SYSTEM Info Codian MCU 8510 4.2(1.46) (Build 6.17(1.46)) starting
2 2013/03/01 09:11:10.200 SYSTEM Info device configuration successfully loaded
3 2013/03/01 09:11:10.868 NETWORK Info SSL successfully initialised
4 2013/03/01 09:11:10.875 NETWORK Info DTLS successfully initialised
5 2013/03/01 09:11:10.892 SYSTEM Info Disabling core dumps
6 2013/03/01 09:11:10.892 UPGRADE Info clearing local features cache
7 2013/03/01 09:11:10.898 CLUSTER Info feature enabled
8 2013/03/01 09:11:10.961 NETWORK Info network_control_init
9 2013/03/01 09:11:10.979 NETWORK Info Initialising IP routes
10 2013/03/01 09:11:11.091 NETWORK Info activating ethernet Port A with auto-negotiation
11 2013/03/01 09:11:11.105 NETWORK Info activating ethernet Port A with auto-negotiation
12 2013/03/01 09:11:11.116 NETWORK Info deactivating port A IPv6
13 2013/03/01 09:11:11.116 NETWORK Info activating ethernet Port B with auto-negotiation
14 2013/03/01 09:11:11.127 SYSLOG Info sending from default port 514
15 2013/03/01 09:11:11.128 NETWORK Info activating ethernet Port B with auto-negotiation
16 2013/03/01 09:11:11.131 UPGRADE Info Hardware compatibility: 00000001 / ffffffff
17 2013/03/01 09:11:11.143 NETWORK Info deactivating port B IPv6
18 2013/03/01 09:11:11.146 NETWORK Info activating ethernet Port A with auto-negotiation
19 2013/03/01 09:11:11.148 NETWORK Warning cannot get network services configuration for interface: dbgname: bogus NETINTERFACE
20 2013/03/01 09:11:11.149 NETWORK Error Connect failed with errno 51
21 2013/03/01 09:11:11.149 TMS_FEEDBACK_EVENTS Warning Notifier (index: 1) unable to connect to 53.154.21.111:80 for sending event notification
22 2013/03/01 09:11:11.171 USER_MANAGER Info 15 users present
23 2013/03/01 09:11:11.173 NETWORK Info activating port A IPv4 with fixed IP parameters
24 2013/03/01 09:11:11.179 CUSTOMIZATION Info customisation configuration read; starting with 1-off 2-off
25 2013/03/01 09:11:11.191 CUSTOMIZATION Info Doing customisation resources init
27 2013/03/01 09:11:11.196 NETWORK Info activating ethernet Port B with auto-negotiation
28 2013/03/01 09:11:11.222 NETWORK Info deactivating port B IPv4
29 2013/03/01 09:11:11.247 NETCONF Info Renewing DHCP on all interfaces to propagate host name
30 2013/03/01 09:11:11.288 SYSTEM Info default text tokens loaded - 6427 tokens (UTF-8 format)
31 2013/03/01 09:11:11.301 RECORD_STORAGE Info record_storage module initialised
32 2013/03/01 09:11:11.303 CDR Info CDR storage available
33 2013/03/01 09:11:11.303 CDR Info Finding archived sections
34 2013/03/01 09:11:11.589 CDR Info Finding current sections
35 2013/03/01 10:11:12.554 CDR Info Current sections OK
36 2013/03/01 10:11:12.555 AUDIT Info Audit storage available
37 2013/03/01 10:11:12.555 SYSTEM Info Unique id change thread starting
38 2013/03/01 10:11:12.589 SYSTEM Info Unique id initialised
39 2013/03/01 10:11:12.589 SHELL Info Serial shell unsecured
40 2013/03/01 10:11:12.605 CAPABILITIES Info Creating 310 capability sets
41 2013/03/01 10:11:12.821 SIP Info SIP initialised
42 2013/03/01 10:11:12.979 H.239 Info init
43 2013/03/01 10:11:12.981 AUTO_ATTENDANT Info initialised - 1 present
44 2013/03/01 10:11:12.998 API Info initialised database
45 2013/03/01 10:11:13.628 AUDIT Error Audit log failed to shutdown correctly in previous boot, audits dropped.
46 2013/03/01 10:11:13.642 AUDIT Info Reading hashes of audit log
47 2013/03/01 10:11:13.642 AUDIT Info Calculating file hashes and checking against read hash
48 2013/03/01 10:11:13.642 AUDIT Info Completed Audit hash check
49 2013/03/01 10:11:21.357 NETCONF Info media connect on vfx0 (3)
50 2013/03/01 10:12:13.410 SYSTEM Info Unique id looking for file with name "/rdwr/persistent_id/conference_id.uid"
51 2013/03/01 10:12:13.528 SYSTEM Info Successfully opened file and read starting id as 32000
52 2013/03/01 10:12:13.588 SYSTEM Info Unique id "conference_id" was written; new allocation is 34000
53 2013/03/01 10:12:13.593 GATEKEEPER Info settings changed - registering all
54 2013/03/01 10:12:13.594 SIP Info Starting SIP TCP service
55 2013/03/01 10:12:13.605 SIP Info Starting SIPS TCP service
56 2013/03/01 10:12:13.605 SIP Info Starting SIP UDP service
57 2013/03/01 10:12:13.729 NETWORK Info Registering tunnel prefix with http handler
58 2013/03/01 10:12:13.730 WEB_PAGES Info page services initialised
03-01-2013 05:11 AM
Yeah. You may need to verify and add a 2nd rectifier to shelf B if possible. What type of blades are they? All 8510's?
I'd check to see if you have another rectifier, and add it to shelf B.
The reboot is a different story, unless the diagnostic.zip file is looked at to be sure. Hopefully it will shed some light.
VR
Patrick
03-01-2013 05:16 AM
Patrick,
1 Codian MSE Supervisor 8050
2 Codian MSE 8510
3 Codian ISDN GW 8321
4 TPS 8710
Unfortunately, i won't be able to send you the diagnostic file as it contains confidential information. Sorry.
03-01-2013 05:19 AM
Patrick,
Is there any docs explaining to decode the diagnostic file contents ?
03-01-2013 05:26 AM
HI Firdaush. No, there are no docs for that file. This is used for TAC and BU purposes only. If you were to raise a case with Cisco TAC, this file would be needed to try hopefully see what happened.
Reference the insuffcient capacity issue, you can check the calculator page cause right now, if shelf A went down or lost power, shelf B, doesn't have enough power to run the chassis.
You can run the calculator here:
90% efficiency on the rectifiers, you will require 2 rectifiers to run the chassis, but since B only has one, and if A were to go down, I don't believe you will have enough power to power the chassis.
VR
Patrick
03-01-2013 06:02 AM
How to know the effeciency of the rectifier?
03-01-2013 06:54 AM
VR
Patrick
03-01-2013 07:17 AM
Perfect.
But do you think that the reboot is due to the incapacity electrical problem?
03-01-2013 07:27 AM
Nothing like a forum discussion to get you thinking about your own infrastructure and it's salability currently in the in the future when you're thinking about adding additional blades.
I have one question on the power rectifiers as the amount of rectifiers in my shelves are the same as Firdaush's. We have two (2) rectifiers in shelf A and one (1) in shelf B, we currently only run one (1) 8510 blade but are looking to add an additional 8510. If I'm calculating this correct, I would need to add another rectifier to shelf B for redundancy just in case A went down, correct?
Can someone tell me what the rectifier efficiency means as well?
Thanks, and sorry for butting into the regional discussion, but thought it was around the same lines and possible preventative measures as what was mentioned previously here would apply to my question.
03-01-2013 08:47 AM
@Firdaush - Not sure without checking out the file which I'm hoping would tell us what happened, but I can't be sure. If you want, you can open a case for investigation if you would like us to. The other rectifier would be important for you to look into also.
@Patrick. Yes, if you add additional blade to your chassis, use the calculator to see how many more rectifiers you may need here. Keep in mind redundancy also. In case you need more on the other shelf as well.
Attached is the H-Series Rectifier data sheet if you need to know more about the efficiency etc.
VR
Patrick
