05-30-2018 09:14 AM - edited 03-18-2019 02:08 PM
When the 88XX phone is in Session Line mode, there are 2 buttons on the right that seem to be default.. a line button (phone) and a Call History button (clock)
I'd like to make the Call History button available on a 10 button template in Enhanced mode but can't figure out how or if it's even possible.
Thanks.
05-30-2018 03:34 PM
Hi there
Couple of questions, how is the configuration for Call History in Two-line mode. Is it configured as service URL on the phone line.
With 8800 series you can enable Enhanced Line mode that enables to program all the 10 keys.
ELM supports CUCM 9.1(2), 10.5(2), and 11.0(1) and any higher releases. You need to install the latest device pack. You can set the line mode in the Product Specific Configuration Layout portion of the Device Configuration window in CUCM
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
05-31-2018 01:23 PM
I don't understand your question about the configuration in 2 line mode?
I already have phones with the 10 lines in Enhanced mode.. but the Call History button isn't available to put in the template.
In Session line mode, it's not in the template either... which is why i said it's a default. It's not in the template.. they just... appear!
05-31-2018 01:25 PM
06-12-2018 09:19 PM - edited 06-12-2018 09:48 PM
I believe this is what you mean:
++ When the 88XX phone is in Session Line mode, there are 2 buttons on the right that seem to be default.. a line button (phone) and a Call History button (clock).
I highly doubt if it is achievable as "call history" is not an options that you can use for a 88XX IP-Phone.
Please check the list of options below that you can use:
Redial
Speed dial
Line
Privacy
Service URL
Speed dial BLF
Call Park BLF
Intercom
Malicious Call Identification
Meet Me conference
Call Park
Call Pickup
Group Call Pickup
Mobility
Do Not Disturb
Quality Reporting Tool
CallBack
Other Pickup
Hunt Group Logout
All Calls
Answer Oldest
Alerting Calls
Queue Status
None
Please rate the post if, helpful.
Akansha Sharma
10-26-2018 03:08 AM
Hello Cabusch,
Upon creating a certain Phone Buttom Template (which you've done already) you can go and create a New Phone Service (without enterprise subscription) by Device->Device settings-> Phone services].
Then you should assign service URL button that is associated with this Service.
The IP Phone Services Configuration
In my case, the Service is described as "History"
if helps, please rate
G
