ā01-29-2019 03:13 PM - edited ā03-18-2019 02:37 PM
We all know that the room kit plus comes with a Quad camera. The question is, can i add a 2nd camera? like the precision 60? Thanks in advance
ā01-29-2019 07:08 PM
ā01-29-2019 07:16 PM - edited ā01-29-2019 07:18 PM
You do not have to buy the RoomKit Plus codec with the Quad Camera - you could purchase it just with a P60 instead (or multiple of).
The RoomKit Plus codec can support up to 3 cameras as it has three HDMI inputs on the back, and each of these can be configured as a "Camera" input.
As mentioned by @Tianjun Zhou, you will need to add an additional switch in between the codec's network port for the camera and the two or three cameras to be able to control them all.
You can use the Input source composition functionality present in the newer CE software releases if you need to show multiple camera sources on the screen simultaneoulsy.
Please remember to mark helpful responses and to set your question as answered if appropriate.
ā05-05-2020 08:53 PM
We do have a room kit pro, any chance we can connect 2 quad-camera on it?My only concern is control. Can the Touch10 can able to control the 2 quad camera?
ā01-29-2019 08:03 PM
Hello Alberto,
Yes, you can connect the Quad cam and P60 camera both on Codec plus.
Please make sure main camera (Quad cam) should be connected on HDMI 1 and the second camera you can connect on 2 or 3.
Please see the admin guide-
Please rate if it is helpful....
ā01-29-2019 09:59 PM
The information that @Anurag Srivastava provided is old, and a for and old verison of the CE software, especially in the diagram where it says that it will only support two cameras.
The current software release (CE9.6.1) supports all three HDMI inputs for cameras. See the same Connect input sources section from the CE9.6 Admin Guide.
ā01-30-2019 04:52 AM
Thank you a lot Wayne.
i supose that both cameras are going to track speakers as usual, right?
ā01-30-2019 06:41 AM
The Precision 60 camera by itself does not do speaker tracking, it only does so when it's part of the complete Speaker Track 60 package.
ā01-30-2019 02:58 PM
The QuadCam can track speakers, but a standard P60 will not - but the P60 can used for some basic "tracking" if you use the codec in PresenterTrack mode, BriefingRoom mode, or Classroom mode.
ā04-18-2019 04:55 AM
Has anyone tried to connect two Quadcams to the Webex Room Kit Plus?
For a space with 2 audience orientations.
ā05-02-2019 02:58 PM
I'm looking at possibility adding two Quad cameras to a Room Kit Plus or Pro as well. If anyone has achieved this, I'd like to hear how this worked out.
ā05-06-2019 06:16 AM
ā05-07-2019 02:11 AM
Great info!
I never used the Video Layout feature, couple of questions though:
a) I assume SpeakerTrack no longer functions in this newly composed (2 x Quad) image?
b) Is it possible to manually pan and zoom or create presets within the composed image?
Thanks again.
ā05-07-2019 04:47 AM
I did turn Speaker Track off. In this setup, i never considered using it, as the composed image is the full room. The P60 presenter track is up and in full use for the podium speaker.
It doesnt look like you can do any form of pan/tilt with the combined image as it is. When i try to do any camera control, it still only lets me choose one. I bet with the macroing system, we can create one that can mimic control of the two cameras, creating the appearance that they are controlled as one.
ā11-10-2019 03:29 AM
Can you mail me the xCommand Video Layout and xCommand Video Matrix commands.Actually i Have one spark kit plus,so i want to add one p60 camera in Spark kit plus.i want both image in one screen.
Can you help me out
My Mail ID :shahink.cp@gmail.com
