01-14-2016 01:46 PM - edited 03-18-2019 05:25 AM
I have SX80's with dual screens that I recently migrated from VCS to CUCM 10.5. We use Acano Manager for bridging. When I have a call up on the Acano bridge and share presentation it appears in the main stream video from Acano for all other participants with dual monitors instead of their 2nd monitor. Before migrating it appeared on the 2nd monitor as it should. I'm think that there might be a setting in UCM that might need updated?
Solved! Go to Solution.
01-14-2016 04:07 PM
Did you follow the Acano 3rd Party Call Control Deployment Guide when setting up the solution, making sure you checked "Allow Presentation Sharing using BFCP" when you setup your SIP Profile in CUCM?
01-14-2016 04:07 PM
02-03-2016 10:41 AM
phifdd4305 did you ever find a resolution? I have the same issue but I have followed the guide that [@patrick.sparkman] linked exactly. Any other thoughts?
02-03-2016 01:25 PM
Yes, it was the "Allow Presentation Sharing using BFCP" on the CUCM check box that Patrick pointed out.
02-03-2016 01:36 PM
Thanks, even with the BFCP being checked on the CUCM SIP profile and the endpoints I am still facing the issue... thanks for again for the quick reply.
02-04-2016 05:01 PM
@phifdd4305 - You mention you are using Acano Manager? Is this 2.0 or 1.x version?
I think we got srumel101 squared away today and found the issue, but need to confirm the above if you can.
Thanks.
VR
P2
02-05-2016 05:46 AM
1.6.9 but I wasn't aware of a 2.x version being out yet.
02-05-2016 06:00 AM
I was referring to Acano Manager not Acano Server. Anyhow 1.6.9 I believe is end of life now and no longer supported. Can you move to at least 1.8 here for Acano Server? If you continue to have problems, PM me, and we can work on whats going on here.
VR
Patrick
02-05-2016 06:49 AM
The reason we haven't upgraded from 1.6 is due to the layout limitations. my executives prefer the all equal layout as opposed to the default active speaker that's the only option after upgrading from what I've seen.
