No camera icon on the phone. (CME 4.0 and 7971)
bascheew
We're running CME and after adding "video" to the ephone and reseting the phone there is no camera icon showing up. Is there anything else we need to add to the config to start video? I even restarted the router with no success.
2811
CallManager Express 4.0
Unity Express 2.3.1
All the phones are 7971
IOS 12.4.4(4)XC2
6 Replies 6
psankara
Do you have 'service phone videoCapability 1' configured under telephony-service in your CME box?
Once you configure this, do a 'create cnf-files' and then reset the phones.
I added that command, and now I see the video icon on the two phones I want to use video for. Thank you!
Now I am not getting video through Unified Video Advantage though. When I have a call between the two phones and I do a "show voip rtp connections" I get a message that says "No active connections found"
"sh call active video" gives me:
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 0
Is there something else I am missing? Everything is running fine in VT Advantage that I can see.
If you do 'show ephone registered', do you see Video in the output for the phones?
Could you attach the configurations being used in the CME? And highlight the two ephones that are being used for the call.
I see video in "sh ephone registered" for one of the phones (ephone 10) but not the other (ephone 14). They are configured the same though. Am I missing something?
ephone 10
device-security-mode none
video
mac-address 0017.954A.4779
paging-dn 1
type 7971
button 1:12 2:5 3m3 4m15
button 5m8 6m13 7m11 8m18
ephone 14
video
username "robin" password XXXXXXX
mac-address 0017.954A.48DA
paging-dn 1
type 7971
button 1:16 2m5 3m6 4m11
button 5m8 6m13 7m3 8m7
telephony-service
video
load 7960-7940 P0030702T023
load ATA ATA030100SCCP040211A
load 7971 TERM70.7-0-3-0S.loads
load 7970 TERM70.7-0-3-0S.loads
max-ephones 36
max-dn 108
ip source-address 10.0.0.1 port 2000
timeouts interdigit 5
time-zone 12
voicemail 6000
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
dn-webedit
time-webedit
transfer-system full-consult
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
I believe you also need:
voice service voip
h323
call start slow
See http://www.cisco.com/en/US/products/sw/voicesw/ps4625/products_configuration_guide_chapter09186a00806a8017.html for more information on configuring CUVA 2.0 with CCME 4.0.
If this helps, please rate this post.
Neal
Could you please ensure that the CVTA is associated with the phone? If both the phones show video icon and 'show ephone registered' doesn't show video for ephone-14, then it probably means that the CVTA is not associated with the phone.
You can double click on CVTA icon and check that the link between the phone and the PC is green.
