Show QoS Markings on SX20
t.svatek
Level 3
Level 3
Is there a way to show the current QoS Marking during a call? This would be very helpfull to verify QoS. There is an option on CTS-Devices, but I haven´t found this on SX20, Codian-MCU etc.
thanks
Tino
Hi Tino, how are you?
There is no real proper way for media statistics and info afterwards on the TC/TE systems, thats not nice
thats true, ... I would +1 on a feature request.
Do you wonder more about what the system tags or what kind of markings it receives?
Having a switch with a monitor port might also worth checking if you do not trust the markings of the
end devices and some more debugging if its on the way in between. Your switches routers
might also be able to give you more info.
If you just want to check whats going on thats nicely done with tcpdump on the endpoint without
the need of tansfering any files.
First check in the xconf which media ports are used, I guess thats the default:
*c xConfiguration RTP Ports Range Start: 2326
*c xConfiguration RTP Ports Range Stop: 2486
Then login as root execute for example:
tcpdump -c 1000 -s0 -v -nl -i eth0  udp and portrange 2326-2484
This should show you whats going on. It will show you the first 1000 packets and then stop, you can reexecute it afterwards if needed.
You will see something like:
10:30:53.432868 IP (tos 0x0, ttl 50, id 0, offset 0, flags [DF], proto UDP (17), length 376)
     vcse.2776 > 192.168.200.10.2478: UDP, length 348
10:30:53.441999 IP (tos 0x88, ttl 64, id 8699, offset 0, flags [none], proto UDP (17), length 1320)
     192.168.200.10.2480 > vcse.2776: UDP, length 1292
This shows you the pacekt from the VCS does not arrive with taging.
Here is a nice site which shows what tos hex value (thats shown in tcpdump) is what DSCP value.
http://www.tucny.com/Home/dscp-tos
In this case 0x88 TOS (hex) = 34 DSCP (dec) = af41 DSCP Class
If you need to know more about which media port is used for what, execute in TSH:
xstatus // Media
Hope that helps :-)
6 Replies 6
Marius Nedregaard
You can do an TCPdump directly from root account in the command line interface ..
You would then be able to identify outgoing and incoming QoS markings
//Marius
Hi Marius
yes, a tcpdump seems to be the only way to do this at the moment, but it´s not too easy to capture rtp-traffic only with it, as you have to know the IPs, Ports and Protocol or you have to transfer it from the codec to your PC to use Wireshark. Not too handy.
Additionally you cannot do this for past calls, where the users created a ticket afterwards. So no chance to check QoS-Markings for these calls.
On CTS-Endpoints is easy: login via web, show call statistics and voila. Also for call history.
thanks
Tino
xstatus // Media
Hope that helps :-)
Thanks Martin , God information :-)
Kind regards,
Dharmmesh
yes. God information ;-)
t.svatek
Level 3
Level 3
any idea how to the the markings on a MCU 4500 ?
