SIP Options Ping and session server-group on dial-peer
aalejo
Level 5
Level 5
Does someone have configured SIP options ping on a dial-peer that uses session server-group?
How server keep track of each individual ip address on the server-group on the dial peer?
In Brief, these two commands on the dial peer:
session server-group <group number>
voice class sip options ping
-Alex
Anthony Holloway
Here's what works for me.
I create a server group class
voice class server-group 1
ipv4 1.1.1.1 preference 1
ipv4 2.2.2.2 preference 2
I then create an empty sip options class
voice class sip-options-keepalive 1
description Server Group SIP OPTIONS PING (Intentionally Left Blank)
Finally, I apply the server group and options classes to my dial-peer
dial-peer voice 1 voip
session server-group 1
voice-class sip options-keepalive profile 1
...other dial-peer commands here...
You can use the following command to view the status of the dial-peer as a whole
show dial-peer voice summary
You can use the following command to view the status of each server in the server group
show voice class sip-options-keepalive 1
8 Replies 8
Adarsh Chauhan
Level 3
Level 3
Please refer to:
http://www.cisco.com/c/en/us/td/docs/ios/voice/cube/configuration/guide/vb_book/vb_book/vb_9321.html
Please rate and mark correct if helpful
Adarsh Chauhan
Adarsh Chauhan
Hi Adarsh
That's the configuration i use but that's when you use a dial-peer session pointing to a single endpoint and not a server group.
Alex
Anthony Holloway
Hello Anthony,
Do you need to have enabled the Ping Options on the SIP profile of the SIP trunk, if the other side of the dial peer is a CUCM ?
Thanks in advance,
George
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
No, you do not. They are separate.
Thanks for the feedback, I ‘ll give it a try
Curious if this ended up working for you. Going through something similar as well, and unsure if I need to creat a SIP profile to insert into the voice class options ping.
Thanks Anthony, great post!
