TMS Default Time Zone
I have a tms ver 14.3.2 an i try to locate How to Change the time zone .
whan i  go to Administration > general setting > it need to be  under the tms release key but it is no showing  there .
i attach a print screan .
It  start Because  my smart scheduler give my a time zone wrong .
help blush
Jens Didriksen
Level 9
Level 9
TMS uses the server time settings as the "default" time, however, individual users can change the time zone relevant to their particular location from within the user details; Administrative Tools/User Administration/Users - select your name and you should see a page like this:
/jens
Please rate replies and mark question(s) as "answered" if applicable.
6 Replies 6
Jens Didriksen
Level 9
Level 9
/jens
Thanks .
Kristof-1
I have similar problem. Windows time zone on the TMS server node is selected properly to UTC/GMT but Monitoring pages show dates in US format.
Does it need to be changed in IIS?
you  need to  change the time under the administrtive tool > user >edit than change it .smiley
OK, I get this part.
However, I don't want to change it for each user but to be able to change default settings for all users.
Hello Krystof -
You'll need to update the time zone settings for each individual user, there is no bulk edit/change capability.
