06-09-2014 03:10 PM - edited 03-18-2019 03:04 AM
I have a tms ver 14.3.2 an i try to locate How to Change the time zone .
whan i go to Administration > general setting > it need to be under the tms release key but it is no showing there .
i attach a print screan .
It start Because my smart scheduler give my a time zone wrong .
help ![]()
Solved! Go to Solution.
06-09-2014 07:06 PM
TMS uses the server time settings as the "default" time, however, individual users can change the time zone relevant to their particular location from within the user details; Administrative Tools/User Administration/Users - select your name and you should see a page like this:
/jens
Please rate replies and mark question(s) as "answered" if applicable.
06-09-2014 07:06 PM
/jens
06-10-2014 08:49 PM
06-17-2014 01:49 AM
I have similar problem. Windows time zone on the TMS server node is selected properly to UTC/GMT but Monitoring pages show dates in US format.
Does it need to be changed in IIS?
06-17-2014 02:04 AM
you need to change the time under the administrtive tool > user >edit than change it .![]()
06-17-2014 02:12 AM
OK, I get this part.
However, I don't want to change it for each user but to be able to change default settings for all users.
06-17-2014 06:41 AM
Hello Krystof -
You'll need to update the time zone settings for each individual user, there is no bulk edit/change capability.
