05-09-2021 03:44 PM - edited 05-09-2021 03:45 PM
I have installed CMS Cluster version 3.1.2
I have a problem with the web app, is when any participant join meeting, the web app drop the participant after couples of seconds from the meeting
with error"unable to reconnect media" > "Rejoin media"
when I rejoin again, 10 seconds later or something, and then knocked out!
For logs: I saw these logs
>>conference 5e08b6a1-dd5f-44bc-9a84-503b80b24db0: locked due to lack of lock consensus
>> configuring call d2c6105d-aa33-4f15-b0ff-9add32f8652e to be deactivated
Solved! Go to Solution.
05-10-2021 06:15 AM - edited 05-10-2021 06:15 AM
CMS directly internally,
BUT AFTER INVESTIGATION WE FOUND THE PROBLEM THAT THE FIREWALL TEAM DIDN'T OPEN THE RIGHT PORTS
BETWEEN WEBRTC CLIENTS AND WEB APP SERVERS
05-10-2021 05:38 AM
do you try to connect to CMS directly internally, or via Expressway?
05-10-2021 06:18 AM
Nice to hear that.
03-01-2022 03:17 PM
what are the ports you opened in Firewall? Guess 443 and 3478.
i have the same error. I am using express 12.7 to provide turn service for cms3.2..
The firewall team said they have opened the ports.I used online port checker to check 3478 but it's showing closed?
can somone assist ?
internal works fine. Only external gues encounter media error
do we need _xmpp-client as srv record in the internal dns since xmpp is not supported on veesion 3.2
