CUC Schedule Not Working
jugalkansal90
Hi Guys,
Looks like my call handler is ignoring active schedule settings, user reported the issue after I restarted CUC cluster.
I have CTI RP pointed to a call handler, in which transfer rules are set to send calls to 'Greetings'. Active schedule is set to 8am-4:30pm. Closed greeting is set to play no recording and 'after greeting' option sends the call to another after-hours CH. During 8am-4:30pm, standard greetings should have kicked in and a day greeting should be played. But right now system is sending all calls to this after-hours CH even in the regular business hours.
Has anybody run into this situation? There was no setting change whatsoever, but after restart this issue came up. Please help.
That is a funky problem. A couple of questions:
1) Is this the only call handler experiencing this problem?
2) If you build a new call handler with the same schedule, does that also suffer from the problem?
Suggestion: Try changing the schedule to something else, save, and then change it back to the original and save. I have seen Unity Connection (and CUCM for that matter) choke on something and this kind of reset will un-choke it.
Let us know how it goes.
Yeah Maren. This issue is little funky. Never run into this kind of issue before.
1) Out of all 5 call handlers, only 1 is working fine and I applied this working CH's schedule to non-working CH and it processed the calls normal, which is great. So , I deleted the schedule which was applied to non-working CH and created a new one, But got the same issue, call goes to Closed greeting.
2) Created a test CH and applied the same schedule and call goes to closed greeting. Even applied all_hours schedule, still goes to Closed Greeting.
Did you get your problem resolved?
I am having the same problem as well.
