Bookmark
Subscribe
1331
Inter-Cluster-Trunk or SIP Trunk between CUCM 7.1 and CUCM 12.X for Inter-Cluster Calling.
aniket0422
Hello Guys,
Can we configure Inter-Cluster-Trunk or SIP Trunk between CUCM 7.1 and CUCM 12.X for Inter-Cluster Calling.
Is it supported ?
Jaime Valencia
SIP trunks are only recommended when CUCM releases are 8.6+, anything below should use an ICT
It should work just fine, it was obviously never tested as 7.x is long EOS/EOL.
java
if this helps, please rate
Jaime Valencia
java
Thanks Jaime,
We configured ICT between CUCM 7.X and CUCM 12.X. Its working fine.
