08-17-2016 11:22 PM - edited 03-19-2019 11:28 AM
HI All
unable to register ip phone on cucm 11 .The phone is getting registered in the devices list but on the phone it gives the ext number and moving to services tab and asking to select services .
It is newly installed PUB
screen shot attached for your reference.
Solved! Go to Solution.
08-19-2016 09:36 PM
You are hitting Default Idle URL. You can find it in User Management > User/Phone Add > Universal Device Template > Auto-registration Template > Service Configuration Settings.
For more info google or look here:
https://supportforums.cisco.com/discussion/12300946/default-idle-url-phones-cucm-10
08-19-2016 09:36 PM
08-22-2016 09:05 AM
This is a correct statement.
Please rate useful posts and mark answers as correct if applicable.
08-21-2016 05:49 AM
Go to the phone page in CM, look for Idle field under External Data Locations Information and remove the entry which is in there followed by reset of phone that should resolve the issue.
Deepak
