Unity Connection PCA gets Java error
jbburks
Level 6
Level 6
Unity Connection 10.5.2 gets Java error trying to play or record greetings.
No support for Java applet: application/x-java-applet;version=1.5
This occurs on IE, Firefox and Opera.
6 Replies 6
Brandon Buffin
Make sure active X is enabled. Also, try the following:
To Update the Media Master Software
Step 1 Close all browser windows.
Step 2 Depending on your operating system, do one of the following:
•For Windows 2000 and later, start the Java control panel by clicking Start > Settings > Control Panel > Java.
•For Red Hat Linux and Mac OSX, start the Java control panel found in $JAVA_HOME\bin\ControlPanel.
Step 3 On the General page, under Temporary Internet Files, click Delete Files.
This clears the cached files. The Media Master resource files will be downloaded the next time you visit a Cisco PCA or Cisco Unity Connection Administration page that contains the Media Master.
Brandon
ActiveX is enabled.
I deleted the Java cache as suggested.
Now I get an error message "This installer cannot continue because the files necessary for installation are unavailable. If trying to install a beta or older version, please check http://java.sun.com/j2se to determine if it is still supported. If so, please try installing at a later time, as these files might be only temporarily unavailable."
I have tried over several days and still get this message.
I really wish the Call Manager group would move away from Java to HTML5.
Did you try with Audio Text available in Cisco Unity Tools and are you still facing the issue.
Deepak
Try greeting administrator
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/unity/5x/administration/guide/ex/5xcusagex/5xcusag250e.pdf
or Audio Text manager
http://www.ciscounitytools.com/Applications/CxN/ATM/ATM.html
I downloaded Audio Text Manager, but it requires administrator permissions. I'm trying to record greetings as an END USER.
ramans2
Community Member
if you are recording a greeting of end user you can simply sign in in the account and chose the option to re recorde the greeting.
If you are trying to record for other users you can have to have
Remote Administrator and System Administrator roles to log in in greeting admin.
if you dont have that option.
you will have to configure the Greeting adminstrator (but you will only be able to record only greeting of call handlers with Greeting admins)
