Problems with MRA configuration
Hi everyone, in my company we are now deploying MRA, but I have some problems configuring the two expressway. In particular i get what you see in the attachments.
Can anyone help? Zones, search rules and domains are properly configured i guess.
Thanks a lot.
I would prefer going with dual NIC.
Example configuration
Expressway C
NIC IP  192.168.10.10 >> VOIP VLAN
Internal  DNS Records
  • Certificate
    • Generate CSR, sign the certificate using Internal CA of domain  internal.domain.it.
    • Upload CA root to trust
    • upload the Server certificate.
CUCM
CUCM IP : 192.168.10.9
Certificate
  • Upload CA root certificate to trust
  • upload the Server server certificate.
_cisco-uds._tcp.internal.domain.it SRV service location:
priority = 6
weight = 30
port = 8443
svr hostname =cucm.internal.domain.it
Do the same with other nodes.
Expressway E
NIC 1 IP  192.168.10.10 >> VOIP VLAN
NIC 2 IP  192.168.20.10 >>DMZ IP
Public IP 45.45.45.26
Internal DNS
  • Create  subzone domain.it
  • A record(Forward and reverse Lookup) in domain.it.  expresswayE.domain.it  192.168.20.10
  • Certificate
    • Generate CSR, sign the certificate using public CA (what ever your provider)
    • while generating CSR DNS filed should have entry domain.it
    • Upload public CA root to Expressway C and E trust
    • Upload root CA of   internal.domain.it  to trust
Public DNS Records
  • A record(Forward and reverse Lookup) expresswayE.domain.it  <<YOUR PUBLIC IP>>
  • SRV   _collabedge._tls.domain.it pointing to above IP/Hostname
when configure dual NIC, use your network design. and the above is just an example configuration.
Response Signature
28 Replies 28
whats the status  of the Zone between E and C is it active ?
Response Signature
First of all thanks for the fast reply. In the attachments the zone status.
The state is in Warning, can you check  why it shows warning. its should show active.
Response Signature
The problem is exactly the one you mentioned. The status should be active, but instead it shows warning with reason "Systems unreachable" and I don't know why.
Is it a single NIC or dual NIC.
Looks like you have issue with SIP reachability . you need to check your configuration.
Response Signature
Scott Leport
Level 7
Level 7
Hi there,
This document will have you covered. Have a look at the "Install MRA" section:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/expressway/config_guide/X12-5/exwy_b_mra-expressway-deployment-guide.html
Thanks a lot, I'll take a look.
Can you also check or share the screenshot from Configuration >> Unified Communication >> Unified CM.
select the call manager and perform and refresh and see if it doesnt give any error?
Yes for sure, thanks a lot. As you can see.. there is a problem on exp-e proxy forwarding.
The error message says that there is no Unified Communication traversal zone between the E and C. Correct that and check again.
Response Signature
yes I read it, but still... zones are configured. You can check the screenshot I already uploaded for more details.
The screen shots show a zone, but not that it’s a Unified Communication traversal zone. Please provide a screenshot of the entire configuration of the zone on both C and E.
Response Signature
Just a question.. on the version X12.5 the zones between exp-c and exp-e must be a Unified Communication traversal or Traversal Client - Traversal Server?
From what I know for MRA it always have to be the Unified Communication traversal specific type of zone.
Response Signature
