08-25-2015 06:31 PM - edited 03-01-2019 12:20 PM
Hi! Experts:
I know there is a bug in CISCO Modular Raid controller Due to Corrupted SAS Expander Firmware. The Raid controller can not be detected by the server. Is there any instruction how to over come this for stand alone C240M4?
Thanks!
Grace
08-26-2015 07:17 AM
Grace,
what is the Firmware version of this Server?
09-28-2015 05:59 AM
09-28-2015 05:59 AM
John,
Can you try to run the Host Upgrade Utility (HUU) against the server and use "upgrade all" and let us know if you still have the same issue...? It wont matter if you use the HUU for the current running version.
https://software.cisco.com/download/release.html?mdfid=286281356&flowid=71443&softwareid=283850974&release=2.0%286f%29&relind=AVAILABLE&rellifecycle=&reltype=latest
-Kenny
09-28-2015 06:05 AM
Kenny,
Thanks for update. I've just updated system using new HUU (6f). Still not working. Any other resolution?
John
09-28-2015 11:35 AM
is the Option ROM, enabled?
-Kenny
09-28-2015 11:59 AM
Yes, All enabled.
09-28-2015 12:02 PM
Only leave enabled:
"All PCIe Slots OptionROM" and the PCIe slot where you have the card.
OptionROM is only used to boot from that card in particular so you dont need to boot from all PCIe cards.
-Kenny
09-28-2015 12:23 PM
Did it. But still RAID is not showing. RAID is using dedicated slot.
09-28-2015 12:41 PM
You better open a TAC case for hardware troubleshooting.
-Kenny
10-09-2015 04:11 PM
when the raid controller is not detect by server, the HUU will not update the firmware for the Raid. Did this raid card ever work before or this is a new replacement? If it is new, then you could run into the bug I was talking about before. It is not so easy to fix. It is better let TAC fix it. By the way, not all TAC know about this bug.
10-10-2015 08:27 PM
RAID card was moved from one server to another. Not detecting after that. Don't know why?
03-17-2021 08:58 PM
I had the exact same situation after a power outage last Friday. The RAID card cannot be detected from C240 M4 since then. I had no clue what's happened.
@John Sharma Was your issue resolved? Was it a firmware bug or hardware issue?
