Cisco UCS Manager - SNMP for Critical & Major Faults (true or false)
doctorouter
Has anyone created a SNMP GET rule in their favorite monitoring system for Cisco UCS Manager to look for Faults?
Specifically Critical and Major fault events?
Orjan
mojafri
Hi @doctorouter,
Configuring SNMP for GETs on UCS is straightforward.
Log into UCSM.
Select Admin Tab > Communication Management > Communication Services
Select 'Enabled'
Enter a community string, contact and location.
Click Save.
Testing SNMP GET
Command line tools:
 (Built into most linux distros and OS X.  Can get NET SNMP for Windows command line http://www.net-snmp.org/)
Get one OID:
Snmpget -v 2c -c public 14.17.193.1 .1.3.6.1.2.1.1.5.0
Get all 'known values' starting at this OID and below (this is probably the simplest way to query a device for SNMP and return a ton of data):
Snmpwalk -v 2c -c public 14.17.193.1 .1
 More specific OIDs can be found here:
https://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/mib/b-series/b_UCS_MIBRef/b_UCS_MIBRef_chapter_0100.html
Please rate if you find it helpful.
MJ
Thanks @mojafri,
I've successfully configured and able to poll the device remotely with SNMP.
My question was more directed to Cisco UCS Fault Event collection with SNMP. From the link you referred to I can find the following rules I'm looking for, but it's SNMP TRAP, not SNMP GET:
Trap Description
cucsFaultActiveNotif This notification is generated by a Cisco UCS instance whenever a fault is raised.
The OID for this SNMP trap is .1.3.6.1.4.1.9.9.719.0.1.
cucsFaultClearNotif This notification is generated by a Cisco UCS instance whenever a fault is cleared.
The OID for this SNMP trap is .1.3.6.1.4.1.9.9.719.0.2.
I'm looking for the above for a SNMP GET.
regards,
Orjan
Hi @doctorouter,
You can use MIB objects and get the IOD using below link:
https://snmp.cloudapps.cisco.com/Support/SNMP/do/BrowseOID.do?local=en
For faults use below MIB:
ftp://ftp.cisco.com/pub/mibs/ucs-mibs/CISCO-UNIFIED-COMPUTING-FAULT-MIB.my
Parent OID for fault: 1.3.6.1.4.1.9.9.719.1.1
Let me know if that helps.
MJ
