Cycles Battery Backup Unit
Josue99
Hello everyone!
I'm have trying to learn the cycle of the Battery Backup Unit, how many cycles? etc.
Kirk J
Greetings.
What specifically are you looking for?
The learning test cycle schedule (which is every 28 days I believe)
The expected life span?, etc
Original BBU/battery, LSI listed replacing every year (or 500 recharge cycles), although we saw those frequently last 3-4 years.
For the Supercap I have not seen published data from Broadcom/Avago/LSI.
The CacheVault-05-UG100_Cache_Backup_Products_UG_v1.0_2017-07-31.pdf doc you can find on Broadcom's website, only mentions the BBU expected replacement cycle, and nothing about expected replacement cycle for SuperCaps.
Kirk...
Kirk J
Greetings.
Kirk...
Hello Kirk!
I looking for the learn cycle schedule.
Your answer about the learn cycle happens every 28 days, help me a lot
Thank you!
pranavgu
Just to add what Kirk has mentioned you can refer to the document below regarding the same.
https://www.cisco.com/c/en/us/support/docs/servers-unified-computing/unified-computing-system/118618-technote-ucs-00.html
Thank you for the information pranavgu.
