Upgrade UCSM without downtime
ZenON
I have question about upgrade UCSM. I have UCSM 2.2(6j) and I want to upgrade to 4.0. I known than I should upgrade first to 3 and next to 4. Is posible Upgrade servers one by one not all in one time?  The point is that I want virtual machines to run on several servers and I will update one
Thanks for help
Wes Austin
Yes this is possible. You want to use host firmware packages on the servers and adjust to the new versions accordingly. Make sure you maintenance policy is set to "user-ack" that way you can reboot each server one by one to apply the changes.
The easiest way is to put a host in maintenance mode, upgrade it by acknowledging the reboot in UCSM, then take it out of maintenance mode and move VM back to it. Rinse, repeat.
Wes Austin
