How to connect the data domain with cisco Fabric Interconnect?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
09-11-2015 08:13 AM - edited 03-01-2019 12:22 PM
Hi Team,
I want to connect the EMC storage and Data domain on fabric interconnect, Is it possible to do that if yes then how?
- Labels:
Unified Computing System (UCS)
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-11-2015 09:39 PM
I dont have knowledge in data domain, but you can directly connect storages and network appliances in FI.
What kind of connection you will use and what is your FI firmware?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2015 10:38 PM
Always check the UCS storage interop matrix
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/mds9000/interoperability/matrix/intmatrx/Matrix8.html
Table 10-2 UCS-B Storage Support Matrix
3) Direct-Attached FC storage to 6120XP/6140XP/6248UP is supported in release 1.4(1) and higher. However, it is restricted to topologies in which the zoning database is provided from an upstream Cisco MDS 9000 switch or Nexus 5000 or 5500 switch.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
09-13-2015 06:38 AM
You can directly attach your EMC storage to your fabric interconnects in several different ways:
1) Direct attached storage via FC/FCoE. The zoning database will be on the FIs and requires FC switch mode.
http://www.cisco.com/c/en/us/support/docs/servers-unified-computing/ucs-infrastructure-ucs-manager-software/116082-config-ucs-das-00.html
2) Appliance ports via ethernet.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/2-1/b_UCSM_GUI_Configuration_Guide_2_1/b_UCSM_GUI_Configuration_Guide_2_1_chapter_0110.html#concept_2BC331760A824A86B0A1F2C69EFDA700
3) Unified appliance port via FCoE or ethernet. Zoning database will be on an upstream fabric switch.
http://www.cisco.com/c/en/us/td/docs/unified_computing/ucs/sw/gui/config/guide/2-1/b_UCSM_GUI_Configuration_Guide_2_1/b_UCSM_GUI_Configuration_Guide_2_1_chapter_0110.html#concept_6B482A1D089E4FC89978A3AFF281569E
Hope this helps,
Justin
