Resolved! SKU for VMware license upgrade to 7
A customer wants to upgrade VMware Vsphere ESXi from 6.7.0 to 7 . which SKU, we need to add in CCW to get the VMware licenses. Regards Hemanth.
The message you are trying to access is permanently deleted.
Hi, Am facing dependency error upgrading from 7.0u3 to 8.0u2e. Before upgrading, have updated the HUU to latest (CIMC). Pls suggest for upgrade or if any Cisco bundle image is available pls share the download path.[DependencyError] On platform embedd...
Hello,We are a VMware shop but we are looking to dip our toes into XenServer since it is included in our licensing. I've been searching around for a "best practices" guide for installing XenServer on UCS-X but not finding much. Hoping someone can p...
Hello All,I have a C220 M6N that will not power on. It appears the Intel ME Node Manager is "unhealthy or unresponsive" per the log and it's causing the server to not power on. I also have a corrupted BIOS, see logs below.Critical F1707 sys/rack-unit...
When I try to update the UCS C220 M3's firmware using the iso file flashed on to a usb it gave the error 906.https://software.cisco.com/download/home/284296253/type/283850974/release/3.0(4s)I also can't get in to the CIMC because I don't know the pas...
Hello.I have Cisco UCS 5108 Cisco UCS B200 M3 (BIOS B200M3.2.2.6h, Board Controller 3.2(3p)B, CIMC Controller 3.2(3p)B, FlexFlash Controller 1.2 build 258-1)After changing the profile, the server stopped loading. Errors in SEL LOGS:69e | 09/23/2026 ...
Good Afternoon,I've come upon an issue that has me stumped. I am setting up some C220 M5's to access remotely, and I am able to reach the PVE's with no issue on all the servers using the Riser 1 PCIe slot populated with a 4x10Gb FX card. The problem ...
Im looking for a visio stencil for the UCS FI-6664 to be posted. Does anyone have that front and rear stencil they can share or know who to contact to update the UCS stencil zip that looks to be last updated in 2025?Thank you,Todd
In our DN2-HW-APL server the Cisco 12G Modular Raid Controller with 2GB cache slot 8 disk shows" unconfigured bad" and the amber light blinks for slot 8 disk.1. Appliance and hardware detailsAppliance model: Cisco DNA Center DN2-HW-APLServer platform...
Hi, I have 2 server (master and slave) BE6H-M5-K9 is based on a Cisco UCS C220 M5.I need to upgrade the CIMC from version 4.1(2a) 4.1(3n)1. Should I upgrade the master or slave first ?2. Please kinldy help with video or step by step procedure docume...
Greetings!Can anyone please help us to determine the following BIOS version are affected under the CVE-2026-20093 or not?C220M5.4.0.1h.0.110C220M5.4.1.1d.0.06C220M5.4.1.3e.0_ISEWhat is the Cisco recommend way to upgrade CIMC vulnerability for C220 M5...
My customer is running 4x C880A M8 cluster, but keep experiencing RAID 1 volume degrade issue whenever OS is booting. (changed to rebuilding status)I've tried rebooting with different type of M.2 SSD (Micron coming from Cisco, Intel Solidigm, and Del...
Cisco UCS 240 M8 Server - CIMC configured but not working facing the same issue in five servers. Connected peer to peer still same issue so did factory reset ping came for few seconds then again, it was not working. Does anyone face this kind of issu...
Body: Hello everyone,I'm seeking some advice regarding an issue with a Cisco UCS C240 M5SX server. On September 17, 2026, the server triggered an unexpected hard reset.Here are the details from the System Event Log (CIMC):Event: BMC WATCHDOG (Watchdo...
Hi all,I have two standalone C-series servers (UCS220 M7) with a VIC 15237 MLOM (100G, QSFP-100G-LR-S) connected directly to IOS-XR routers.The vNIC is in Trunk mode with no default VLAN, VNTAG mode is disabled, and Physical NIC Mode is on so that Li...
| Subject | Author | Posted |
| 03-10-2026 08:31 AM | ||
| 12-03-2025 07:07 AM | ||
| 11-30-2025 06:22 PM | ||
| 09-23-2025 12:33 PM | ||
| 09-09-2025 06:54 AM |
