Problem:Outbound calls disconnected after 19 sec
zeinab.mahdavi
Dear All,
we have provided outbound calls from our application that is registered to a sip proxy server ,the sip proxy route the call to the cisco as5350 xm ,
and the call is connected successfully , the sip server send the 200 ok and the gateway send ack , but this process is continuing until the call is disconnected after 19 sec, in this duration we have seen 7 200 OK and ack send and recieves.
the configuration of as5350 XM is as the below :
   25     resource-pool disable
   26     no aaa new-model
   27     !
   28     resource policy
   29     !
   30     spe default-firmware spe-firmware-1
   31     !
   32     !
   33     ip cef
   34     !
   35     !
   36     isdn switch-type primary-net5
   37     !
   38     voice call send-alert
   39     voice call disc-pi-off
   40     !
   41     voice service voip
   42      fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
   43      modem passthrough nse codec g711alaw
   44      sip
   45       bind control source-interface GigabitEthernet0/0
   46       bind media source-interface GigabitEthernet0/0
   47       ds0-num
   48       header-passing
   49       registrar server
   50       no call service stop
   51     !
   52     !
   53     !
   54     !
   55     !
   56     !
   57     !
   58     !
   59     !
   60     voice translation-rule 1
   61      rule 1 /^199/ //
   62     !
   63     !
   64     voice translation-profile OUT
   65      translate calling 1
   66      translate called 1
   67     !
   68     voice translation-profile call
   69     !
   70     !
   71     !
   72     !
   73     username pendar privilege 15 secret 5 $1$fGxh$0hiSg//QgvwKyXvFyqefA1
   74     !
   75     !
   76     controller E1 3/0
   77      pri-group timeslots 1-31
   78     !
   79     controller E1 3/1
   80      pri-group timeslots 1-31
   81     !
   82     controller E1 3/2
   83      pri-group timeslots 1-31
   84     !
   85     controller E1 3/3
   86      pri-group timeslots 1-31
   87     !
   88     !
   89     interface GigabitEthernet0/0
   90      ip address 10.121.43.201 255.255.255.248
   91      duplex auto
   92      speed auto
   93      negotiation auto
   94     !
   95     interface GigabitEthernet0/1
   96      ip address 217.219.184.82 255.255.255.252
   97      duplex auto
   98      speed auto
   99      negotiation auto
  100     !
  101     interface Serial0/0
  102      no ip address
  103      shutdown
  104      clock rate 2000000
  105      no dce-terminal-timing-enable
  106      no fair-queue
  107     !
  108     interface Serial0/1
  109      no ip address
  110      shutdown
  111      clock rate 2000000
  112      no dce-terminal-timing-enable
  113     !
  114     interface Serial3/0:15
  115      no ip address
  116      encapsulation hdlc
  117      isdn switch-type primary-net5
  118      isdn incoming-voice modem 64
  119      isdn T306 400000
  120      isdn T310 400000
  121      isdn bchan-number-order ascending
  122      no cdp enable
  123     !
  124     interface Serial3/1:15
  125      no ip address
  126      encapsulation hdlc
  127      isdn switch-type primary-net5
  128      isdn incoming-voice modem 64
  129      isdn bchan-number-order ascending
  130      no cdp enable
  131     !
  132     interface Serial3/2:15
  133      no ip address
  134      encapsulation hdlc
  135      isdn switch-type primary-net5
  136      isdn incoming-voice modem 64
  137      isdn T306 40000
  138      isdn send-alerting
  139      isdn bchan-number-order ascending
  140      isdn sending-complete
  141      no cdp enable
  142     !
  143     interface Serial3/3:15
  144      no ip address
  145      encapsulation hdlc
  146      isdn switch-type primary-net5
  147      isdn incoming-voice modem 64
  148      isdn bchan-number-order ascending
  149      no cdp enable
  150     !
  151     interface Group-Async0
  152      no ip address
  153      encapsulation slip
  154      group-range 1/00 2/59
  155     !
  156     interface Group-Async1
  157      physical-layer async
  158      no ip address
  159      encapsulation slip
  160      async mode interactive
  161      no peer default ip address
  162     !
  163     router rip
  164      redistribute connected
  165      network 192.168.0.0
  166     !
  167     ip local pool dialin_pool 10.1.2.1 10.1.2.96
  168     ip default-gateway 192.168.10.1
  169     !
  170     ip route 0.0.0.0 0.0.0.0 217.219.184.81
  171     ip route 0.0.0.0 0.0.0.0 192.168.10.1
  172     ip route 192.168.75.0 255.255.255.0 192.168.10.1
  173     no ip http server
  174     !
  175     !
  176     access-list 101 permit ip any any
  177     dialer-list 1 protocol ip permit
  178     snmp-server community public RO
  179     !
  180     !
  181     !
  182     control-plane
  183     !
  184     call treatment on
  185     call threshold global cpu-5sec low 50 high 80 treatment
  186     call threshold global cpu-avg low 50 high 80 treatment
  187     !
  188     !
  189     voice-port 3/0:D
  190      disc_pi_off
  191      input gain 3
  192      output attenuation -3
  193      echo-cancel coverage 32
  194      no non-linear
  195      playout-delay mode fixed
  196      no comfort-noise
  197      cptone DE
  198      timeouts call-disconnect infinity
  199      timeouts wait-release 180
  200      bearer-cap Speech
  201     !
  202     voice-port 3/1:D
  203      disc_pi_off
  204      input gain 3
  205      output attenuation -3
  206      echo-cancel coverage 32
  207      no non-linear
  208      playout-delay mode fixed
  209      no comfort-noise
  210      cptone DE
  211     !
  212     voice-port 3/2:D
  213      disc_pi_off
  214      input gain 3
  215      output attenuation -3
  216      echo-cancel coverage 32
  217      no non-linear
  218      playout-delay mode fixed
  219      no comfort-noise
  220      cptone DE
  221      bearer-cap Speech
  222     !
  223     voice-port 3/3:D
  224      disc_pi_off
  225      input gain 6
  226      output attenuation -3
  227      echo-cancel coverage 32
  228      no non-linear
  229      playout-delay mode fixed
  230      no comfort-noise
  231      cptone DE
  232     !
  233     !
  234     !
  235     dial-peer voice 20 voip
  236      service session
  237      destination-pattern 2268T
  238      session protocol sipv2
  239      session target sip-server
  240      dtmf-relay rtp-nte
  241      codec g711alaw
  242      no vad
  243     !
  244     dial-peer voice 10 pots
  245      translation-profile outgoing OUT
  246      service session
  247      destination-pattern .+
  248      no digit-strip
  249      direct-inward-dial
  250      port 3/0:D
  251      forward-digits all
  297     !
  298     sip-ua
  299      credentials username 1111 password 1315121C0F0D16 realm ipv4:10.121.43.202
  300      credentials username 1111 password 014255550E5A545E021C68593D5441 realm pendar
  301      credentials username 1113 password 051B0301254D5C realm pendar
  302      authentication username 1111 password 105E0C17011600
  303      no remote-party-id
  304      no redirection
  305      srv version 1
  306      retry invite 2
  307      retry bye 1
  308      retry refer 3
  309      retry register 10
  310      timers notify 400
  311      timers refer 567
  312      timers register 100
  313      registrar ipv4:10.x.x.xexpires 60
  314      sip-server ipv4:10.x.x.x
  315     !
  316     ss7 mtp2-variant Bellcore 0
  317     ss7 mtp2-variant Bellcore 1
  318     ss7 mtp2-variant Bellcore 2
  319     ss7 mtp2-variant Bellcore 3
  320     !
  321     line con 0
  322      logging synchronous
  323      stopbits 1
  324     line aux 0
  325      stopbits 1
  326     line vty 0 4
  327      login local
  328     line 1/00 1/59
  329      modem InOut
  330     line 2/00 2/59
  331      modem InOut
  332     !
  333     scheduler allocate 10000 400
  334     ntp broadcastdelay 10
  335     ntp clock-period 17180080
  336     ntp update-calendar
  337     ntp server 217.218.158.42
  338     ntp server 195.146.63.100
  339     end
debug ccsip messages for one outbound call :
Telconi Terminal 1.01
direct TELNET to 10.121.43.201 [10.121.43.201] from 10.121.43.202
Default to IOS device.
ACCESS-118#
Sep 14 07:22:22: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:19909126131721@10.121.43.201:5060 SIP/2.0
Via: SIP/2.0/UDP 10.121.43.202:5060;branch=z9hG4bK-57fa4f40-11a3-4247-ba33-5abdfb3ce731-ppco
Max-Forwards: 10
Contact: <sip:100@10.121.43.202:5060>
To: "bd030c0f-0f0e-4c53-a71d-02df901aa822@10.121.43.202"<sip:19909126131721@10.121.43.202>
Call-ID: bd030c0f-0f0e-4c53-a71d-02df901aa822@10.121.43.202
CSeq: 1 INVITE
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, NOTIFY, MESSAGE, REGISTER, SUBSCRIBE, INFO
Supported: replaces
User-Agent: UMSV
Graph-Track: #1:1>
Content-Type: application/sdp
Content-Length: 198
v=0
o=- 88211 88211 IN IP4 10.121.43.202
s=UMSV
c=IN IP4 10.121.43.202
t=0 0
m=audio 6936 RTP/AVP 8 101
a=rtpmap:8 PCMA/8000
a=ptime:20
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
Sent:
SIP/2.0 100 Trying
To: "bd030c0f-0f0e-4c53-a71d-02df901aa822@10.121.43.202"<sip:19909126131721@10.121.43.202>;tag=F2EB328-1553
Date: Sat, 14 Sep 2013 07:22:22 GMT
Server: Cisco-SIPGateway/IOS-12.x
CSeq: 1 INVITE
Allow-Events: telephone-event
Content-Length: 0
Sep 14 07:22:23: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:10.121.43.202:5060 SIP/2.0
Via: SIP/2.0/UDP  10.121.43.201:5060;branch=z9hG4bK54801998
To: ".+" <sip:.+@10.121.43.202>
Date: Sat, 14 Sep 2013 07:22:23 GMT
Call-ID: E7F05D17-19F611E3-80068889-D18125B9
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1379143343
CSeq: 1818 REGISTER
Contact: <sip:.+@10.121.43.201:5060>
Expires: 60
Content-Length: 0
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.121.43.201:5060;branch=z9hG4bK54801998;rport=5060
To: ".+"<sip:.+@10.121.43.202>
Max-Forwards: 70
CSeq: 1818 REGISTER
Expires: 60
Content-Length: 0
Sep 14 07:22:27: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, COMET, REFER, SUBSCRIBE, NOTIFY, INFO, UPDATE, REGISTER
Contact: <sip:19909126131721@10.121.43.201:5060>
Content-Length: 0
Sep 14 07:22:28: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
o=CiscoSystemsSIP-GW-UserAgent 6982 8340 IN IP4 10.121.43.201
s=SIP Call
c=IN IP4 10.121.43.201
t=0 0
m=audio 16388 RTP/AVP 8 101
a=fmtp:101 0-15
a=ptime:20
Received:
ACK sip:1111@10.121.43.202:5060 SIP/2.0
Max-Forwards: 10
CSeq: 1 ACK
User-Agent: CallCenter
Content-Length: 0
Sep 14 07:22:29: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Sep 14 07:22:30: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Sep 14 07:22:32: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Sep 14 07:22:36: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Sep 14 07:22:40: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Sep 14 07:22:44: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Length: 250
v=0
s=SIP Call
t=0 0
a=fmtp:101 0-15
a=ptime:20
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Sep 14 07:22:45: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:10.121.43.202:5060 SIP/2.0
Via: SIP/2.0/UDP  10.121.43.201:5060;x-ds0num="ISDN 3/0:D 3/0:DS1 26:DS0";branch=z9hG4bK5481D52
To: <sip:2268000@10.121.43.202>;tag=758019368
Call-ID: 3B8C672A-1C4511E3-96718889-D18125B9@10.121.43.201
Max-Forwards: 70
Route: <sip:2268000@10.121.43.202;ftag=F2EB4A8-14E;lr=on>
Timestamp: 1379143365
CSeq: 102 BYE
Reason: Q.850;cause=16
Content-Length: 0
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.121.43.201:5060;branch=z9hG4bK5481D52;rport=5060
Max-Forwards: 70
CSeq: 102 BYE
Content-Length: 0
Sep 14 07:22:46: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
BYE sip:1111@10.121.43.202 SIP/2.0
Via: SIP/2.0/UDP 10.121.43.202:5060;branch=z9hG4bK-c4a2ddc9-d8df-4e86-8fd7-954ad58290ee-ppco
Call-ID: 25A950E2-1C4511E3-96598889-D18125B9@10.121.43.201
CSeq: 2 BYE
Max-Forwards: 10
To: <sip:3243502@10.121.43.202>;tag=F2E2538-D6C
P-hint: rr-enforced
Route: <sip:10.121.43.202;ftag=F2E2538-D6C;lr=on>
Content-Length: 0
Sent:
SIP/2.0 200 OK
Date: Sat, 14 Sep 2013 07:22:46 GMT
Content-Length: 0
CSeq: 2 BYE
Sep 14 07:22:48: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:100@10.121.43.202:5060 SIP/2.0
Via: SIP/2.0/UDP  10.121.43.201:5060;branch=z9hG4bK548218FD
From: "bd030c0f-0f0e-4c53-a71d-02df901aa822@10.121.43.202"<sip:19909126131721@10.121.43.202>;tag=F2EB328-1553
To: "100"<sip:100@10.121.43.202>;tag=400231974
Max-Forwards: 70
Timestamp: 1379143368
CSeq: 101 BYE
Content-Length: 0
Received:
SIP/2.0 200 Ok
Via: SIP/2.0/UDP 10.121.43.201:5060;branch=z9hG4bK548218FD;rport=5060
Max-Forwards: 70
CSeq: 101 BYE
Content-Length: 0
would you please help me to underestand what the root cause of this problem?
4 Accepted Solutions
Probably the problem is in the ACK message:
Received:
Max-Forwards: 10
To: "bd030c0f-0f0e-4c53-a71d-02df901aa822@10.121.43.202"<19909126131721>;tag=F2EB328-1553
CSeq: 1 ACK
Content-Length: 0
The request URI in the ACK must be the Contact from the 2xx response.
Try to use sip:19909126131721@10.121.43.201:5060:
ACK sip:19909126131721@10.121.43.201:5060 SIP/2.0
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Regards.
Who are subjects of communication?
INVITE from 10.121.43.202, user-agent: UMSV ---> to Cisco AS5350 10.121.43.201
TRYING from Cisco AS5350 10.121.43.201
180 RINGING from Cisco AS5350 10.121.43.201
200 OK from Cisco AS5350 10.121.43.201
ACK from 10.121.43.202, user-agent: CallCenter ---> to Cisco AS5350
The first INVITE come from "UMSV".
The ACK came from "CallCenter".
Regards.
I've already answer. The problem of disconnection is due to an inconsistent URI in ACK received from AS5350.
You must fixed your application.
In the log you can see the AS5350 that sends multiple 200 OK because doesn't understand the ACK. The timeout is about 20 seconds.
first 200ok:
Sent:
SIP/2.0 200 OK
last 200ok
Sent:
SIP/2.0 200 OK
timeout
Sent:
Use "debug ccsip all" to confirm.
Regards.
If the config is the same, you can load the IOS of working scenario.
I expect the same behavior.
Regards.
9 Replies 9
Received:
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
Regards.
but how can I revise the ack , it must be done in 5350 or in the PBX ?
Regards.
we fixed the User-agent but the problem still remain .
apart from the Ack , why does it disconnect after 19 sec, If the ack and 200 ok has problem the connection wouldn't be established at all.  but the connection is OK , we can have conversation in both side but after 19 second is disconnected ,... is it need to set some parameteres in as5350 ? or it must be resolved by Telco? may be our application send this disconnection ????
another thing is that our inbound calls doesn't have any problem , we faced with this problem when we want to make a call from our softphone to PSTN.
I am really confused with this problem
first 200ok:
Sent:
SIP/2.0 200 OK
last 200ok
Sent:
SIP/2.0 200 OK
timeout
Sent:
Regards.
Dear Sir,
I have noticed something strange, we have another center with successful outbound call
the "debug ccsip message" displays as follows:
*Sep 22 22:17:30.076: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Cisco#
*Sep 22 22:17:22.264: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:19909126131721@217.218.20.88:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.86:5060;branch=z9hG4bK-9033762f-21a3-4a73-90fb-6f6371811faa-ppco
Max-Forwards: 10
Contact:
To: "5229e37a-0eae-42ea-96c0-c8eb0037e03f@217.218.20.86"<19909126131721>
Call-ID: 5229e37a-0eae-42ea-96c0-c8eb0037e03f@217.218.20.86
CSeq: 1 INVITE
Supported: replaces
User-Agent: UMSV
Graph-Track: #6:1>#1:17>
Content-Length: 199
v=0
o=- 88211 88211 IN IP4 217.218.20.86
s=UMSV
c=IN IP4 217.218.20.86
t=0 0
m=audio 17801 RTP/AVP 8 101
a=ptime:20
a=fmtp:101 0-15
Sent:
SIP/2.0 100 Trying
To: "5229e37a-0eae-42ea-96c0-c8eb0037e03f@217.218.20.86"<19909126131721>;tag=1493B7A4-26C2
Date: Sun, 22 Sep 2002 22:17:22 GMT
CSeq: 1 INVITE
Content-Length: 0
*Sep 22 22:17:26.744: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 180 Ringing
CSeq: 1 INVITE
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
Contact: <19909126131721>
Content-Length: 0
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Content-Disposition: session;handling=required
Content-Length: 249
v=0
o=CiscoSystemsSIP-GW-UserAgent 1770 426 IN IP4 217.218.20.88
s=SIP Call
c=IN IP4 217.218.20.88
t=0 0
m=audio 17826 RTP/AVP 8 101
a=fmtp:101 0-16
a=ptime:20
Received:
ACK sip:1112@217.218.20.86:5060 SIP/2.0
Max-Forwards: 10
CSeq: 1 ACK
Content-Length: 0
*Sep 22 22:18:01.968: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
BYE sip:system@217.218.20.86:5060 SIP/2.0
Via: SIP/2.0/UDP 217.218.20.88:5060;branch=z9hG4bK4DC31428
From: "5229e37a-0eae-42ea-96c0-c8eb0037e03f@217.218.20.86"<19909126131721>;tag=1493B7A4-26C2
To: "system";tag=1289485100
Date: Sun, 22 Sep 2002 22:17:30 GMT
Max-Forwards: 70
Timestamp: 1032733081
CSeq: 101 BYE
Content-Length: 0
there is One Ok and One Ack , furthermore the ack is
the configuration of as5350 is the same as first one that I mentioned it in previous messages
How is it possible !!!!
by the way, we are trying to revise the Ok and Ack in Sip dll template, However if anything else that we must cosider, I am really appreciate telling me.
Dear Daniele,
I found the error in "debug ccsip all" message :
from the first gateway I found that after ack it faced with error so it transmit another 200 Ok
Received:
ACK sip:1113@10.121.43.202:5060 SIP/2.0
Via: SIP/2.0/UDP 10.121.43.202:5060;branch=z9hG4bK-65a22302-cb5d-4684-ab07-d21bf659108e-ppco
Max-Forwards: 10
To: "77c16348-e88d-4e57-a234-cf47af12289d@10.121.43.202"<19909126131721>;tag=1E0714C8-229C
Call-ID: 77c16348-e88d-4e57-a234-cf47af12289d@10.121.43.202
CSeq: 1 ACK
Content-Length: 0
Sep 17 04:33:33: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg: Invalid method for (STATE_IDLE): ACK
Sep 17 04:33:34: //21838/2151511CA876/SIP/Transport/sipSPISendInviteResponse: Sending 200OK Response to the Transport Layer
Sep 17 04:33:34: //21838/2151511CA876/SIP/Transport/sipSPITransportSendMessage: msg=0x65D52AA8, addr=10.121.43.202, port=5060, se
ntBy_port=5060, is_req=0, transport=1, switch=0, callBack=0x00000000
Sep 17 04:33:34: //21838/2151511CA876/SIP/Transport/sipSPITransportSendMessage: Proceedable for sending msg immediately
Sep 17 04:33:34: //21838/2151511CA876/SIP/Transport/sipTransportLogicSendMsg: switch transport is 0
Sep 17 04:33:34: //-1/xxxxxxxxxxxx/SIP/Transport/sipTransportPostSendMessage: Posting send for msg=0x65D52AA8, addr=10.121.43.202
, port=5060, connId=0 for UDP
but in the second gateway that we have successful call we observed following messages:
Received:
Via: SIP/2.0/UDP 217.218.20.86:5060;branch=z9hG4bK-856eba9a-360a-4fdb-87cf-026735f9a9d7-ppco
Max-Forwards: 10
To: "3bed38f0-30ec-42f8-bdfa-d8c813401f1b@217.218.20.86"<19909126131721>;tag=2389DB44-219D
Call-ID: 3bed38f0-30ec-42f8-bdfa-d8c813401f1b@217.218.20.86
CSeq: 1 ACK
Content-Length: 0
*Sep 25 20:01:00.418: //-1/xxxxxxxxxxxx/SIP/Info/ccsip_new_msg_preprocessor: Checking Invite Dialog
*Sep 25 20:01:00.422: //44001/55364B20A789/SIP/Info/sipSPIFindCcbUASRespTable: *****CCB found in UAS Response table. ccb=0x66C252
2C
*Sep 25 20:01:00.422: //-1/xxxxxxxxxxxx/SIP/Transport/sipSPIUpdateResponseInfo: Subsq Transaction Address 217.218.20.86,Port 5060
, Transport 1, SentBy Port 5060
*Sep 25 20:01:00.422: //-1/xxxxxxxxxxxx/SIP/Info/sipSPISetDateHeader: Clock Time Zone is UTC, same as GMT: Using GMT
*Sep 25 20:01:00.422: //44001/55364B20A789/SIP/Info/act_sentsucc_new_message_request: Transaction Complete. Lock on Facilities re
leased.
what do you think ? what different between the processing of ack in these two ACK? all the headers are the same so where is their differences ?
Also,searching Net , I found a documet about caveat for cisco IOS release 12.4 which mention this error :
Symptoms: DTMF path confirmation is not received for a SIP call.
Conditions: This problem is due to an issue with th
e SIP state machine, which may result in an error
along the lines of the following:
00:05:10: //-1/xxxxxxxxxxxx/SIP/Error/sipSPISipIncomingMsg: Invalid method for
(STATE_IDLE): ACK
The call state should not be IDLE
In your Opinion , with upgrading the IOS , is the problem solved?Or we must solve it in our application?
Regards.
I have already got the result .
we provide Ack Request same as invite header field ....
IOS upgrading is not a proper solution , thanks for your answer and time , It was really helpfull
